Favorit alloys for Felicia?
Hi All
Simple question - Would the Favorit Alloys fit on the Felicia? There are a few going on e-bay for as low as 50 quid, with good tyres.
Any guidance will be appreciated.
If the wheels are from a later model Favorit, then yes they should. Both these and the Felicia have a 4x100pcd wheel bolt pattern.
Very early favorits have 4x98 pattern, so their wheels won't fit directly on a felicia hub.
Favorit alloys will fit the Felicia as they are the same size as the steels (165/70 R13)
I have seen the same ones on Fleabay but the distance from me wass a bit of a downer.
Thanks for the replies. Will keep an eye for any Favorits with alloys breakng close to where I live. The one's on e-bay are quite far from where i live.
Thanks once again
Same for me here, they're all miles away. Already have a good few as I managed to get a set from Nottingham a while ago for £50. When they're £50 for a full set it's cheaper than buying new tyres and I can mix and match the best ones :) It's also cheaper than a rim re-seal if your rim is leaking.
Plus I love the plastic centre caps :D
I might just get a full set of mine refurbed anyway when I have the cash.
