Seat removal?
Hi. Please could someone tell me how to remove the front seats from the fabia vrs? I'd like to remove them for cleaning if it's not to difficult.
Many thanks.
Luko.
there are 4 bolts , one basically at each corner of the seat , push the seat back to access the front bolts, and push it forward to access the rear bolts
you will need a 12 point spline socket to remove them , and ideally the bolts should be renewed , not re-used
Or use a bit of thread lock on the old ones.
In that case. I think I'll clean them in the car!
Thanks for your help.
Luko2
It's an M10 spline drive fitting. :)
Many thanks.
Luko.
god whats happened to them? if you need to remove them from the car to clean them:eek:
From reading previous posts, removing the seat covers is a bad idea (difficult to get back on).
