Booost Gauge...... With pics
Well today i have been mostly re-organising my dash to incorperate my boost gauge.
Ive moved the headunit to the bottom slot and made a holder for the gauge.
Might move the parrot 3100lcd screen to the gap to the left of the boost gauge this afternoon.
Heres a pic, sorry for my rubbish photography skills before someone says :D
Looks very stock. :thumbup:
Afraid I did go for the plug & play option with my gauge setup, but for me my car is nearly always about function over form. :D
looks good mate - be nice to see how it looks with the parrot fitted flush to the left - just check you can see the screen clearly at that angle - may need a small plastic wedge to tilt it a bit.
I wouldnt have the cahunas to take a drill to my dash though matey :thumbup:
what model parrot is that again ? Looks v different to the 31K I've just re-bought.
the parrots not in the picture, that grey box above is my GPS Origin B2 Cam Detector :D
I don't think it is a parrot is it?
doh...
very nice looking work there. same HU as me too :)
ive just fittted a volts gauge into my non skoda. being a NA engine a boost gauge woudlnt have cut it really lol!
got the wheels on yet?
Great works, looks mint.
ah I see
well at least it's on.... I mean it's not a dead parrot is it?
Wheels are on matey :thumbup:
:D
looks really nice was the boost gauge hard to fit??
I am a real novice so where would you connect your boost gauge to?
if you know what i mean ?
Not really if u know what your doing, took a pro like me :rofl: about 30mins to do.
This particular boost guage is a digital 3 bar one.
IT has a pickup which is connected via a small vac tube to the boost pipes just before they enter the inlet manifold.
The unit itself needs a +ve a -ve and a +switched power supply.
Is there a need for a boost gauge other than aesthetic?
I was just wondering that...
Do diesels have that much boost that you could see much movement?
Wheels look good by the way...
My rear windows were that tint when i first got it from work, but i removed them as they were too dark, it looked like a van!
How do you get on with them mate?
Much movement :rofl: They generally boost more than petrols :eek:
Mine boosts to 1.7 bar and holds that to about 4200rpm where it drops to about 1.3 bar :D
Thanks, car just need lowering to suit ;)
Yer I liked them with the standard wheels, but they dont suit the white wheels.......... Been thinking of ripping them off for a while. Might go do it now :rofl:
I think mine looks better without...personal preferance etc..
Yeah mine needs lowering...ive priced some eibach up today...its tempting!
Ive been banned from buying anymore kW Stuff at work :rofl: Must have sold near on 2k worth :eek:
I recon i am gunner still try and get some 35mm springs and dampers before i leave
Where do you work?
Just wondered with you ordering KW stuff...
Hey Skud - How much can you get replacement springs for the KW V1 for? ;):rofl:
PS: As for boost movement! :eek: Until you have seen a boost gauge on a TDI go way past 2.5 bar, you never realise why a 20psi gauge is highly unsuitable for a TDI. I've maxxed this baby out, although steady max boost is 1.8 bar (when not in limp mode. :rolleyes: ) PS: I am a fan of a needle for a boost gauge though. Means a bit more to me than digital, yet I prefer digital for other readouts... odd, eh? :D
Hmm...Are they easy to fit?
Might consider one...
Just for asthetics mind...!
Easy enough. :D
Needed:
1) Big drill bit to drill through dash. ;)
2) Boost pipe feed from intercooler system
3) Electric feed if backlit
4) dashpod or similar to the above
Mine is a bit brutal, but effective. ;)
Triple gauge pod for boost, EGTs, water temps & oil temps
PS: boost pod has been levelled out now. :o
Single pod for oil pressure. :D
HELL!
That is brutal!
Hmm...might have a look at getting one after the remap etc...not much point on a semi standard car eh!
