Possible another turbo bites the dust
Coming back from the girlfriends house this evening, accelerated away from the lights and there was a very high pitch squeel, then a bang, then smoke :eek:
STopped the engine straight away, and called my little bro who came with the hilux and towed me home.
I recont he turbos gone again :thumbdwn: theres a nice patch of oil under the car atm, but will have to wait and see what tomorrow brings.
To say i am ****ed off is an understatement! :mad:
Sounds like the squeal and bang might have been a boost pipe splitting leading to loads of smoke. Hope you get it sorted. :(
Hope it is just a boost pipe Wouldnt explain the oil mind :(
Was it under the turbo, or more behind the front right wheel? Because if it popped off near the SMIC, there's always some sludge in there. ;)
There is a fair amount of oil in the boost pipework from the crankcase breather. If you've popped a lower section of pipe it could have spat a load out.
Edit - Jason beat me to it
Of course, the solution to that oil is to reroute the CCV pipework. ;)
Thanks guys :thumbup:
Just been out to the car with a tourch and the oil is defo coming from behind the drivers side wheel. Which hopefully means its a boost pipe thats gone.
CAnt wait to get the undertray off and have a peak. might go do it now in the dark :)
Those dodgy VAG clips again! :rolleyes:
I'm so happy to have uber-clips on all my boost pipework. None of my boost pipework is going to pop - in fact I think my boost hoses are rated lower than the clips, so technically they would pop/tear before the clip actually gave way. :cool:
Well I am pleased to announce, my furbys all well again.
Twas a damn boost pipe :mad: I should have known this, feel like a noob :eek:
Only think that put me away from boost pipe was seeing oil patchs on my drive.
But jason/vrsfab was correct it was just crap from inside the intercooler.
Cant wait to get my allard pipe and ccv pipe on :thumbup:
Have you resecured the clip with anything extra to stop it happening again?
PS: I'm always right.... :rolleyes::D
No not yet, just popped it back in place, will be uprating the whole intercooler system shortly so will just leave it till then, gunner leave the undertray off for a few weeks then if it happens again ill be able to fix at the side of the road :D
undertray? :confused: :D
:rofl: Weight saving again was it :rofl:
Nope - just easy access to the sump for oil changes, plus I reckon it helps with cooling a bit. :thumbup:
i'd agree with that :thumbup:
Apparently it's just a noise-deadener (also I think it works well to keep cats out of the engine bay in cold weather - will not tell you a nasty and expensive horror story that happened in a mate's beamer...).
Didnt notice any difference in warm-up time or any over-heating even during an Arabian summer....
Noisier without and would keep any road muck from splashing up into the engine....
I know its a PITA to keep taking off and putting back on, but it's there on the car, likely for a reason.....
