Favorit Mono motronic 5 pin diagnostic connector - how could it be used?
  • 1 year later...
The Haynes Fault Code Manual gives procedures for reading fault codes and to clear them using an LED and a jump wire incorporating a switch . ISBN 1 84425 175 6.
The dealer VAG 1552 with an adaptor works with it, so it follows that VAG Com/VCDS will as well with an adaptor.
I'll move this to the Favorit/Felicia section.
I wonder if the adaptor is just a simple wire to wire affair, and if maybe there's a part number with which one could be ordered from a dealers.
I managed to get some pictures of a Favorit cable that connects to the 2X2 port above. In therory it should be possible to make your own, though I don't know if the rocker switch attached to it serves another function.
27127.attach
27128.attach
27129.attach
27130.attach
27131.attach
