can i remove door strips??
can i remove door strips or will it leave a line of ghastly holes in my doors?? oh i drive a fabis VRS
thank you
Yes
thank you
No
HTH
A kitten is killed, they should be made indangered species on this forum :rolleyes:
:D:D:D:D:D:D
Yes, with help from a heat gun to heat the adhesive up and help with removal then a bit of elbow grease with some Auto Glym Intensive tar remover
mine are mega mega glued on if you dont have a glue gun what another way thanks
Pick your computer up and throw it are the door strips - that should help to loosen them.
Alternatively, you may wish to try using it to search on www.briskoda.net
we just used hot water and they came away easy :) the just clean and polished :)
Chris
By removing your door stripes will give the car a clean looking appearance mate, but as others have said it is just held on with adhesive
cheers mate bloody laptop is broken now cheers for your advice lol
Chris
is skolding water the best to use and how long after water applied should you try and get off cheers thanks
I'm in a better mood today!
Have a look at http://www.briskoda.net/forums/fabia/fabia-door-strips/51980/ for more tips and tricks
Toffee wheels, caramel wheels, dental floss, fishing line, petrol, WD40, Tesco Club cards, screwdrivers wrapped in cloth - its got the lot :thumbup:
cheers mate going to have a go with a covered flt screwdriver this weekend fingers crossed lol
I wouldnt do that!!
Bucket of hot water,
Peel em off,
Then scrub away with either Auto Glym Intensive Tar remover £4 Halfords, or a rag and some petrol :thumbup:
I personally wouldnt put a screwdriver anywhere near my paintwork :thumbdwn:
why not mate? can i use a screw driver to take the initial lip up to then pull away cheers mate
yeah but be carful, usually hard metal objects and paint dont mix very well :rofl:
Should come off easy enough with your hands :thumbup:
Extension lead and a hairdryer. Much easyness.
They will be harder to remove at this time of year. Nothing like leaving the car in the baking summer sun, to help loosen the glue.
One thing to keep in mind, especially if your car is used. If the door has been resprayed at some point and you remove the strip, you will end up with a line where the new laquer and old paint meet.
cheers guys this is my plan:-
cover a flat bladed screwdriver so it does not come in contact with the bodywork
then with a hairdryer/warm water start to easy it away
the car has not been sprayed i dont think lol and its an 06 plate so fingers crossed should be no fade
many thanks
fingers crossed
Mine was almost two years old when I took the strips off, absolutely no fade at all (red car). I used a hairdryer, a stool (for sitting) and my hands to pull them off. I considered a screwdriver but even trying to get that behind the strips when covered scared me so gave up before I started.
Start at the back and use your nails and it's easy enough. Once there's enough off to get a finger behind it's childs play. Last thing you want is to slip with a screwdriver and need to touch up the paint though.
very true mate going to have a stab this weekend just need to find a spare hair dryer co my girlfriend will go barmy lol
Maybe best to be a bit more gentle than that!
