17 instrument cluster
Just looked into my instruments cluster I can only set one setting either 02 for seatbelt warning, or 01 for brake pad warning. 04 for washer warning, I know my car has washer warning & brake pad warning sensors but how do I add all 3 of these features ? 00 mabe :confused:
[17] - Instrument Cluster
00??x0x: Options
+01 = Brake Pad Warning
+02 = Seatbelt Warning
+04 = Washer Fluid Warning
+16 = Sedan (only VW Jetta)
00xx?0x: Country
1 = Europe (EU)
2 = USA (US)
3 = Canada (CDN)
4 = Great Britain (GB)
5 = Japan (JP)
6 = Saudi Arabia (SA)
7 = Australia (AUS)
00xxx0?: Distance Impulse Number
1 = 22188
2 = 22076
3 = 21960
4 = 21848
5 = 22304
6 = 22420
7 = 22532
Add the numbers: 01+02+04 = 07 and sets all three.
Thanks Bruce, so it should look like this.....
00010204x0x or 0007x0x instead of this 0002x0x
What was your original coding?
Hi Stu, my origional coding is 00 for ?. 02 for seatbelt warning, 4 for GB, & 01 for distance impulse number ?, So....... 0002401 thanks
Don't mess with distance impulse sender and you shouldn't need to mess with the country.
For the options AFAIK it's all the same digit so if you had 02 (Seatbelt Warning installed) then to add Brake Pad warning the number becomes 03 and to further add Washer Warning it becomes 07.
However it is not for sure your car has these so if you enable them and get a warning it will mean they aren't fitted.
Ok thanks Stu, so my coding will be 0007401, I will pop this in later, my car does have these sensors fitted, I must have changed 07 to 02 by mistake :rofl: as I was trying to put my dash back to miles from Km.
Just got full VAG-COM-HEX yesterday & having fun learning new things everyday :thumbup:
sorted :D. put in 07 all now working, can't find my factory alarm anywhere to change the siren tone to german settings :confused:. also activate the second rear fog light!!!
Cont 46
Cont 23
thanks Stu, Just done another scan & keep getting P0671 & P0672 glow plugs 1 & 2 cylinders, Load 0.
Are these glow plugs easy to change, my engine is 1.9PD AVQ. VW Touran
Also my manual does not show me where to check the power steering fluid level :rolleyes:
:rofl:
My abilities don't stretch to power steering level on the Touran I'm afraid.
cheers, filled up my washer bottle today & the computer is telling me to fill washer fluid, :confused:. This did not happen before ??? could something else need resetting
Yep - Possibly as I predicted above, if you don't have it and enable it you get a warning.
thanks Stu, will have a look tommorow to see for sure, purple/white & brown/white wires are for the sensor, main job for tommorow is changing the glow plugs, going for BERU ones from german & Swedish, are they difficult to get to, im guessing the lower windscreen cover at the back of the enginewill have to come off :eek:
Your problem aren't the plugs, more likely their control module/relay. ;) Mind posting an Auto-Scan from the vehicle in question so we can have a closer look at the faults and other control module data?
On the swedish mk1, there's no cable for the rear right fog light. Check so you have cable to both lights before activating it.
Sorted, plugs 1&2 were 210 Ohms while 3&4 were 1.3 Ohms. Replaced all 4 in 10 mins :thumbup:. Only cost £43.00 for 4 BERU plugs, & the ones taken out were BERU also, Standard VW fitment poss.
Done three scans ign on/off & three output tests vag-com on the glow plugs & no more faults.
