Add a autodazzle and lights for mirrors (lot of pics)
Hi all
Long time I wished to add in my mirrors:
- ambient lights
- autodazzle
- lowering with rear gear
For autodazzle (or autodimming, I don`t know how to say right) it is necessary to have interior mirror with autodimming. For lowering - atleast variable resistor in mirror for feedback. I found a complete mirrors from L&K version with all options.
So.
New mirror witout cover. Small socket - for analog signal from interior mirror for auto dimming
Ambient light (5W)
Standart mirror without cover
First step is to remove door trim
Second - change the mirrors
Wires for autodimming is in A-pillar (red arrow), so we need to make a wires only from mirror to A-pillar inside door. For ambient lights all wiring already done on a factory
Making a wiring
...And wiring from variable resistors to door electronic module
Result
Lowering is not working. I will need seat controlu module or door control module from Golf V. To be continued... ))
Funnily enough I sat in a colleagues L+K last week and commented on the rubber seal around the mirror glass.
Does that suggest he has auto dim mirrors ?
Still amazed at how bad the car looks with a few plastic casing removed... almost makes it look like a write off
Good work though - people without puddle lights will be showing lots of interest..
Yep, the rubber seals on the mirrors are only found on the auto dimming variety, dropped from the >2007 L&K spec :thumbdwn:
Fitting the auto dimming door mirrrors doesn't look like it will be too bad on an L&K :rubchin:
If you can share any more speciffic information on the mods, such as:
1. Pins used on the A pillar connectors
2. Should you not connected the A pillar to the door controller, then the door controller to the mirror?
3. Colors of the wires in the A pillar connector
4. How did you dismantle the A pillar connectors
That would be most appreciated.
Thank you.
Thanks for the information! I was commenting to my better half the other day that its a shame the Elegance doesn't have dimming wing mirrors as well, anyone know where we might be able to source the parts required for the mirror replacements. I already have the dimming rear view mirror so looks like it should be resonably straight forward :)
  • 5 months later...
