Add a autodazzle and lights for mirrors (lot of pics)
Hi all
Long time I wished to add in my mirrors:
- ambient lights
- autodazzle
- lowering with rear gear
For autodazzle (or autodimming, I don`t know how to say right) it is necessary to have interior mirror with autodimming. For lowering - atleast variable resistor in mirror for feedback. I found a complete mirrors from L&K version with all options.
So.
New mirror witout cover. Small socket - for analog signal from interior mirror for auto dimming
Ambient light (5W)
Standart mirror without cover
First step is to remove door trim
Second - change the mirrors
Wires for autodimming is in A-pillar (red arrow), so we need to make a wires only from mirror to A-pillar inside door. For ambient lights all wiring already done on a factory
Making a wiring
...And wiring from variable resistors to door electronic module
Result
Lowering is not working. I will need seat controlu module or door control module from Golf V. To be continued... ))
Nice work Andrey.
Pity about the reverse lowering, I'll give it some thought and email you.
Funnily enough I sat in a colleagues L+K last week and commented on the rubber seal around the mirror glass.
Does that suggest he has auto dim mirrors ?
Still amazed at how bad the car looks with a few plastic casing removed... almost makes it look like a write off
Good work though - people without puddle lights will be showing lots of interest..
Can always rely on you for good info and write ups :thumbup:
Excellent post, keep up the good work.
Top job there. Interested in that idea.
Yep, the rubber seals on the mirrors are only found on the auto dimming variety, dropped from the >2007 L&K spec :thumbdwn:
Fitting the auto dimming door mirrrors doesn't look like it will be too bad on an L&K :rubchin:
If you can share any more speciffic information on the mods, such as:
1. Pins used on the A pillar connectors
2. Should you not connected the A pillar to the door controller, then the door controller to the mirror?
3. Colors of the wires in the A pillar connector
4. How did you dismantle the A pillar connectors
That would be most appreciated.
Thank you.
Thanks for the information! I was commenting to my better half the other day that its a shame the Elegance doesn't have dimming wing mirrors as well, anyone know where we might be able to source the parts required for the mirror replacements. I already have the dimming rear view mirror so looks like it should be resonably straight forward :)
  • 5 months later...
is an even simpler led to the ambient light (5w) ?, not a bulb? knows someone code? me I would be interested to bring an white led.thanks
