What's the most common Felicia Complaint?
What's gone wrong with your Felicia, Fun etc. in the last 12 months? 7 members have voted
  1. 1. What's gone wrong with your Felicia, Fun etc. in the last 12 months?
    • Thermostat
      12%
      23
    • Coolant Temp Sensor
      8%
      17
    • Suspension
      10%
      20
    • Throttle Body Gasket
      2%
      4
    • Lights
      6%
      12
    • Central Locking/Alarm
      3%
      7
    • Head Gasket
      1%
      3
    • Cabin Electrics
      2%
      5
    • Exhaust system
      8%
      16
    • Radiator/hoses
      3%
      6
    • Steering
      3%
      6
    • Gears
      4%
      8
    • Brakes
      6%
      13
    • Clutch
      4%
      8
    • ECU
      1%
      2
    • Rust
      12%
      24
    • Windscreen/windows
      8%
      16
Please sign in or register to vote in this poll.
Only once in eleven years has my Felicia failed to get me home, and that was due to a duff battery - replaced with heavy duty one on the spot by roadside assistance.
CV gaiters were replaced four years ago, apart from that, only the rear exhaust incident ( friends thought this very funny), has incurred repair/replacements costs.
Last month in a dark car park I noticed what seemed to be a piece of twine hanging out of the exhaust of my '97 Felicia. Thinking that kids had been playing around, I pulled it out ... and out! A warning light went off in my head. Using the scissors on Swiss knife trimmed "twine" back to exhaust tailpipe and drove home listening for untoward noises of distress.
Turned out the rear exhaust box packing was disintergrating : replacement cost, including labour and VAT, £53.-
With maintainance costs like this, I will not need a free bus pass!
My ´98 felly diesel has been in the family for 9 years, now on 105k miles and living it up in Spain!
Last 12 months = an expensive year!
Diesel warm start bypass switch - 3 quid
Cut out broken Cat convertor - replaced with s-steel custom pipe - 70 quid
also new center and rear box (fitted myself - stupidly cheap from ebay via Germany)
new wheel bearings - 10 quid per side
new sus. joints for MOT - 8 quid per side , wish I´d gone for full wishbones though - loads of agg and pattern parts so rubber boots split already!
plus wear and tear items
new battery (duff one from Halfords, replaced under Guarantee)
new brakes all round
new tyres
The best thing is that cars get such a hiding in Spain that my felly looks pretty respectable now!
Great car, will be keeping it as long as I can.
Are catalytic converters not a legal requirement in Spain then? Or have I misunderstood you?
ill let you guys decide whats common failures here:
lower arms both sides
new front bearings
new front hub x 1
new front shocks + full upper mounts
new alternator
new battery x 3 (now FIXED)
new alternator belt x 2
new throttle body
new MAP sensor
new ECU
new HALL EFFECT sensor
rebuilt ecu --> injectors--->throttle body wiring loom from scratch.
new front cv boots x 4
new rear brake cylinders (i cant believe a garage replaced just one)
new rear bearings x 2
full exhaust from cat onwards
im not including consumables like fluids, service parts, brakes or tyres here either.
but i have NEVER NEVER had a problem with the thermostat or coolant temp sensor. go figure :o
nice things about felicity:
no rust in any important or load bearing structure whatsoever. bit of rust right under boot lock and thats it.
she doesnt drink oil or coolant
homely engine rattle due to never ending but worn timing chain (it just "suits" her)
nice stereo :)
soon to be wearing some new shiny shoes :)
In the last 6 months:
- thermostat failed
- ignition lock fell to bits
- ABS wheel sensor failed
- bottom balljoint failed
- central locking on o/s/r door
- o/s/f wheel bearing now rumbling like a good 'un
- car does hot start when it's cold and vice versa - ecu/sensor problem?
- seized brake caliper
- instrument panel lights intermittent, great fun at night
- bonnet cable snapped (this morning's little treat)
My old Favorit was better than this.
Oh - diesels dont need Cat converters in the UK , as long as they pass the emission test they are fine - as for in Spain , lets hope not!
