felica blower intermittant
felica blower intermittant , is this a common problem and how do i fit it, thanks darren
Sounds like a dodgy connection or maybe more likely you should look for a new switch/resistor (at your local scrappie of course). I've never done it so cannot give much useful information, but no doubt there someone else will come along shortly.
Is it the same problem in all positions? I had an old Audi where the fan worked on 1, 2 and 4 but only seldom in position 3 - I just got used to it.
Really need to know what you mean by "intermittant". If it's as Swedish describes, and only one position doesn't work, it's probably the switch, but might be the connector that relates to that speed.
If it's on-off at all speeds, it's probably the common connector, but might be the switch.
It's worth trying to spray WD40 on the wiring connectors inside the fan housing as I managed to get mine to life doing that. Could be the recent weather. It's an easy quick thing to try anyway.
just realised if i slam the bonnet the fan comes on! tidy! lol
It's a connector, or else the fan motor bushes then! :eek:
WD 40 in the fan bushes should help at least temporarily...
Try tapping the underside of the fusebox.
A proper electrical service spray would be better. Try the WD40, and if it works, buy the right stuff.
Yes this has cured the "something not working" type problems for me sometimes.
have you heard of viagra? :rofl:
The fusebox :rolleyes::rofl: It tends to be the headlights or sidelights, tap fusebox and they come on. Doesn't happen often enough to be annoying though.
