high flow cat
was interested in a milltek high flow cat any1 tried these? r they worth it? wat kind of gains can i expect from this? thanks
You will get little power gains, what will happen is the turbo tends to spool a little quicker, and this is best taken advantage of with a custom map. TBH you can remove the cat altogether.
Will removing the cat not damage anything?
Just get someone to make you a straight through pipe about £60 - £80 ;)
It's possible. It's better to map it accordingly.
Just decat and do away with it. Think a decat pipe is about £85 IIRC
