Rear wash wipe probs????
Now then all, during the cold snap last week my rear wash wipe stopped working, i can hear the pump working and water trickling but its not coming out of the jets, ive had a quick look under the bonnet but all the hoses seem attached correctly, the water trickling noise seems to be coming from the grey plastic cover under the hatch window, i guess the answer is that a pipe has come off under there but is there anything i need to know abt taking the cover off, in my very brief look i couldnt see any clips or anything obvious to help remove, any advice woud be bang on , cheers Vin.:thumbup:
yeah mine did this last week.
just pop the panel off (you have to give it a good tug but be careful not to break any clips) and refit the hose, with a tight zip tie or something to stop it coming off again.
Oh and the clips at the bottom of the screen are at 90degrees to the others so you have to slide it up the screen to release the top clips.
to put the panel back on you have to slide it down the window to 1st clip in the top hooks, then push the rest on, making sure all the clips are lined up.
its a bit of a pain getting the panel on and off so dont try to do it in a hurry!!
Cheers bodge, ill have a go now, l8rs pal. Vin
Finally got round to doin it, wot a nightmare gettin off, had to really yank it , now sorted, cheers.
