Engine Warning Lamp Lit
Hi Guys
I had my engine warning lamp on last Thursday. I ran vagcom on Friday (thanks mluton!!!) and got the following:
Address 01 -------------------------------------------------------
Controller: 06A 906 032 HJ
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 78392
TMBSL21U138667811 SKZ7Z0B1396626
1 Fault Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 F
Component: ESP ALLRAD MK60 0104
Coding: 0023174
Shop #: WSC 31480
No fault code found.
Address 08 -------------------------------------------------------
Controller: 1U1 907 044 A
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 31480
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1U0 920 911 B
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 23412
Shop #: WSC 31480
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 3Y Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 31480
Address 56 -------------------------------------------------------
Controller: 1U0 035 161 D
Component: Radio GRO 0001
Coding: 00407
Shop #: WSC 31480
End -------------------------------------------------------
He reset it but unfortunately it has come back on today. Has anybody got any ideas of what I could try?
Chris
It's too lean at idle, check for air leaks from the breather hoses close to the dip stick.
Mine came on yesterday - looks like my lambda sensor is away (from VAG Com) - will find out on Sat for sure.
Thanks.
I had a quick look at the breather pipe but couldn't hear any hiss. Had a quick feel but it was covered in crap so will have to have a better look at the weekend.
Cheers for the help.
Chris
