Oct II xennon fitting
Is there away to adjust the org. xenon lamps on the oct II whith normal lamps.
Recode the central unit or somethig?
Sorry on my english.:D
I wouldn't think you could fit normal lamps to replace HID lamps.
If it was RHD I'd have offered to swap he light housings :rofl:
nou too fit xenon instead normal lamps
What about the other systems needed such as self leveling and washers?
The only thing you could do is fit some HID look alike bulbs.
I did change xenon lights instead of normal lamps, I also did upgrade, that you can use manual leveling with xenon lights!!! you have to swap headlight beam motors with xenon lights and change wiring as well.. no problem.. works fine on my car..
Re: you have to swap headlight beam motors with xenon lights and change wiring as well.. no problem
Will the beam motors just fit in the org. Xenon headlights ?
What wiring change ?
Henrik
You have to take out wires from connector inside normal lamp going to beam motors and put them into the xenon lights, also with beam motors... beam motors from normal lamps will not fit correctly, you have to change fittings on the end... {smaller ball on the end]... it is also very hard to take out beam motors from normal lamps.. I have done it many times, so I know how...
