Fabia Vrs 18" Fitment
HI
WHAT FITTMENT DO I NEED TO FIT 18" RIMS TO A FABIA VRS?
i.e 8" wide etc
WHAT TYRE SIZE ?
PLEASE CAN SOME ONE TELL ME
MANY THANKS
8" wide will be fine. 5x100 PCD
I had 215/35 18s on mine, and thats spot on for a Fabia vRS.
You need to make sure you get the correct offset, this will depend on the width of the wheels... ideally you want ET 42-47 IIRC, but don't quote me on that. :)
Thanks for that!
does that mean that 18" rims from an octavia will fit as the 17" standard octy rims do?
thanks
No, the 18" ones off the octyII are a different fittment.
Octy II fitment are 5x112 PCD
Octy I fitment are 5x100 PCD (same as Fabia).
wil i be able to run 40 profiles with the 18s or is that to much do i need 35s?
thanks
40 is too much.
You need 215/35/18 I'd have thought.
Wouldnt 18s be pretty bad for the handling and acceleration?
Not to mention the ride and comfort....
You definately need 5 x 100, 18 x 8 fit a treat with 215/35/18's. If the wheels are heavy - ie replicas, expect handling and acceleration to suffer slightly. No scrubbing lowered on 25mm eibachs either. :thumbup:
If I was to put 18's on again, i'd use 18 x 7 or 7.5, just to get some rim protection from the tyre.
19 x 7 also fit :)
