Nearly gave the service reception guy a heart attack
My car is due its first service, but is also in need a some warranty work, to date they have replaced anti roll bar & bushes to try and cure suspension creaking on the front & this faild.
Re washer pipe has popped of twice & on one occasion caused the high level brake light to remain on all the time, and various parts replaced, anyway here this list a things to be sorted on the first service.
1. Replacement front windscreen.
2. All suspension bushes to be replaced
3. New headlights(due to condensation)
4. New high level brake light(condensation & poor washer performance, sometimes its powerful, others times its not)
4. Check steering geometry as rear tyres very noisey & I mean noisey but wearing OK.
5. Gear lever notchy & makes a graunching noise when chaging gear.
6. The bloody flywheel.
The receptionist who is new could not believe the amount of work required, I will keep you updated, but car going to dealer in 3 weeks time.
Blimey.
Is this a diesel model per chance?
Did you buy a LADA? :eek:
Blimey.
56 reg 1.9 tdi estate
I thought the flywheel was on 2.0TDi that had to be changed? and not 1.9.
Both are effected wit flywheel issues.
Headlights misting is usually considered normal as they arent a sealed unit, i'm guessing by now on a 56 plate all of the ones that have been modified have been. There was a recall on them sometime ago with regards to blocking a vent hole.
hi - what symptoms are you having with the flywheel?
