Briskoda external logo question
Regarding the small external briskoda stickers, normally applied above headlight.
What is the method for applying them, are they just self-adhesive or are they like the old
'air-fix' transfers you float on with water then dry out?
If removed do they leave stubborn adhesive behind?
Finally, as they're only showing black in stock, any pics of black on race blue?
Thanks chaps:)
Its just like a normal sticker that you stick on I didnt use any water.
you just peel off the backing paper,apply to clean bodywork and rub with a cloth. then carefully peel back the clear adhesive strip and hey presto the sticker is applied. i have one under the rear numberplate and one under the tdi badge on the tailgate.quite fetching if i say so myself.:)
put a bit of wax over the area first, it will make it easier to remove if you ever need to. also to remove hot soapy water does good.
I generally don't use wax as this does not let the sticker adhere to the clean surface. I found the edges start to come up from thr paint. I use a detailer and clay to smooth the area flat then apply sticker and then use a hair dryer to gently warm the sticker then use a clean cloth to rub down on the backing. After this I leave the sticker to adhere to the car for a day before I wash or clean the car.
Hi mate , I like the badge on your steering wheel.Can i ask where you got it from please
When are the silver ones comin back in stock?? Said at the end of the month but we are now here and nothin as of yet
Just a tip dont put them on the rear window I've got mine there and the wiper has scratched it quite badly now.
Hi Dakar, Thanks I tried a number of stickers before I ended up with this one.
Here is the link.
Skoda Octavia Fabia VRS 3D Wheel Centre Badges Decals on eBay, also Decals, Exterior Styling, Car Tuning Styling, Cars, Parts Vehicles (end time 15-Mar-08 21:22:12 GMT)
I got the 60mm ones. If you get stuck I might post you one for the price of postage. I can't exactly use the remaining 3 for the wheels...
Thanks for that mate ,if i have no success i might take you up on your offer:thumbup::thumbup::thumbup:
