Drivers door unlocking issue
Hi. Would like to know if anyone has experienced this problem:
When I unlock the car using the remote, quite a few times when I go to open the drivers door, it will not open on the first pull of the handle but then opens on the second pull! It's like the feature you have from th einside when the car is locked but you can open the door on the 2nd pull of the handle. The other doors all open as normal. It's a bit annoying but I can't figure out why it sometimes happens! Anything to do with the door latch????
I would think it's part of the locking mechanism sticking slightly, the action of pulling the door handle probably completes the unlocking process meaning you can open the door properly the second time.
I would get it down to your dealer to check it out in case it gets worse.
That's not normal - and damn annoying! I would get it checked out.
