Multi Funktion Steering wheel
I have a 4 spoke Elegance leather steeringwheel
can i just move the cover and airbag to a 4 spoke multi steering wheel
The new steering wheel: 1Z0419091 6/h
Are all the connections already there or does i need a new stelring or cable?
I'm aware that i need some vag-com coding.
Henrik
Henrik
You'll need a new aribag wiring loom but the existing airbag is fine. You may also need a new steering controller that supports Multifunction.
I assume the steering wheel is complete with buttons and the controller in the wheel itself.
The Steering Wheel looks to have everything installed.
The Loom - 1K0 971 584 C is around 35 Euro
The Controller 1K0 953 549 AQ or AK s around 140 Euro
You wrote that i MAY have to buy a controller
How do i find out if i need one ?
Where should it be placed ?
Henrik
Henrik
You can check the part number with VAG-COM.
It is fitted under the steering column around the area of the reach/rake adjustment.
Yes it must be a 'AK' module i need
I have a 'AF' module and a 'AQ' module doesn't support multi func. wheel
Cruise Control Retrofitting (1K) - Ross-Tech Wiki
Henrik
Yes it does. I have AQ module and it works just perfectly.
Yes it does. I have AQ module and it works just perfectly. Today 14:52
Did you already have the AQ in or did you put it in yourself ?
Henrik
Henrik
I had an 'F' ending control module, so I had to buy a new one and change that. I did the whole steering wheel swap myself, it was pretty easy. It took something around 50 - 60 minutes to do. Including coding of the new controller.
