Chewing Gum - Grrrrr
Quite annoyed really. :mad:
Didn't realise I had some gum on my shoe and it is now firmly gummed in to the drivers mat!!!
Does anyone know a way I can get this off without ruining my mats??
Put your mat in the deep freezer then scrape off the frozen chewy
I was advised to freeze the garment (a coat in my case) and chip the gum off whilst it could be fractured into bits. It worked well.
Cool,
Will give it a try.
Shreds is on nights so I can smuggle it in too!!
Ta
you can buy "freeze spray" ......spray it and then hit it with a hammer and it shatters
Freezing it definitely works, or you can buy bubblegum remover. I'm sure SWMBO has a litre of it knocking about.
If you cant remove the mat.Use a large ice cube and rub it over the gum and then break it out in small pieces.
Was gonna suggest liquid nitrogen, but think the freezer idea may be easier/more accessible :rofl:
Steve
If freezing doesn't work, there is a chewing gum remover in the Stain Devil range.
NEW-SOL They use it on the busses for getting chewing gum and tar off the seats Grumpy has some
Well mat is now in the freezer so will give it a try in the morning.
Hi all,
ta for all the advice. The freezer failed so I popped to our local wilkinsons to try and find some of the stain devil stuff. Antway I got this spray on stuff for £3.99 which I am pleased to say has worked a treat.
The mat is now clean again.
You could have tried peanut oil as that will work :)
