HELP please! Top mount nut...
Hi
Just started replacing my front springs... How do you get the top mount nut loose? I got a hex socket on the inside and a spanner with a huge lever on the nut but I cant get the bugger undone?!?
Help please..
Many thanks
Ideally you need a box spanner mate. But if you've got purchase on it and it just wont turn, give some penetrating oil a go... They will be stiff for sure.
They are really tight, I managed to bend a hex socket into a nice spiral trying to undo mine!
As already said - lots of penetrating fluid and hard work
Left = loose
right = tight
just incase lol. :-)
Hi
Help please..
Many thanks
you do have spring compressors clamping the spring ? :eek:
its a lot easier to undo if access to an air impact gun is available
Thanks for the tips guys;
I do have spring compressors. Should I be fitting these before I undo the top nut? I thought I would be using them once the unit is off the car?
I do have a compressor but no impact gun, perhaps I should invest, I take it if I use one there is no need for the hex wrench in the middle?
cheers
chris
Left = loose
right = tight
Are you saying that the nut should go clockwise to undo? :eek:
I been turning anti-clockwise on the nut and clockwise on the hex/bolt.:rolleyes:
the nut will undo anti-clockwise
you need to get the shocker off and the spring clamped before undoing the nut
You should 100% be clamping the spring before undoing the top nut yes!!!
