Can I manually adjust the camber of the rear wheels to avoid excess tyre wear?
Can I Manually Adjust The Chamber Of The Rear Wheels To Avoided Excess Tyre Ware
your not supposed to be able to because the stub axles are fixed....
but a trick i learned rallying was to unbolt the stub axles and stick shims under one side to increase the camber....
i dont recommend it tho on a road car.. leave it well alone
Note to self. Check blue book :rofl:
Chris
Micheldever tyres adjusted mine ok. :confused:
There are revised figures from Skoda regarding tyre wear. 1.25 degrees as opposed to 1.45 degrees.
