3 Folding Questions...
1) I see on the folding control panel that there is a check box to 'disable highly optimised code'.....Will it make any difference to the folding rate with this off?
2) What is the above mentioned anyway???:confused:
3) will running the folding kill the processor faster than normal (providing that the chip is kept at the machine managed temperature)?
Mine seems to run at about 45 - 50 degrees C then the fan will speed up, is this ok?
Is there any software to download that I can speed up the processor fan a little just to be sure that it's cool - not so it's fast but a little??
Thanks,
Ben
Yes, your WUs will take at lest 3 times as long to complete. Your progress will dop from say 10-15 mins per % to more than 1 hr per %.
The application uses the extra SSE code builtin to most CPUs. This is designed as a boost for number crunching.
The processor life will not change, I have been folding for the team for 3 years. Some of the machines have been upgraded but one or two have been folding 24/7 for this time.
Those temps are fine, and you shouldnt worry at all.
Thanks, thats brilliant, I shall keep folding :thumbup:
Ben
