steering rack noise
my 57 plate vRS' steering rack creaks quite often on full lock? is this normal for a electro-mechanical steering rack? first time i've owned a car with it, im used to hydraulic and normally getting a woosh from the pressure release valve
Cheers,
Dan
Holding any P/S fully over for any length of time is supposed to do damage isn't it?
At least that is what I've always seen in numerous owners' handbooks!
Not so much on full-lock but mine creaks as I turn left at low speed, it also only seems to be there when the air temp is cold?
Really strange problem, sounds like its generating from a steering servo or something, anyway getting it checked out this week.
W.
hmm think i'll mention it next time its at the stealers
AFAIK it was a fault with them and they were being replaced under warranty. It was on a 2006 garage car I drove, the car was only a couple of days old too.
Yes as I understand it but then was told these were definately pre 2007 builds :confused:.
mines a 57 plate, then again, could have been sat about a year first before it was registered for all i know
The dealer can read a number off the rack (MBV 80 iirc) this will tell them if its in the effected range of steering racks.
Lummox,
I've been reading a little about this from previous posts & just wanted to know if it is this 'common' steering rack issue that also effects Golf mk5/Leon etc... is it a big job? What is involved - the whole steering rack replaced or the servo/motor?
Just to be more precise - the noise can only be described as a 'creaking' sound & only present when actually turning the steering wheel left, the noise stops when you stop turning the wheel so is also NOT present when on full left lock. The noise also seems to be coming from behind the glove box area & sounds like an electric motor/mechanical sound (hard to describe). I can also confirm that this is only audible when it is cold outside (below 10deg). I just know that when it goes in again this week, the dealer will not be able to pick it up because the weather is getting warmer!
Thanks, W.
