stand alone case for hard drive?
I can remember someone saying about a USB case that you slide a normal hard drive into so you could read it......does anyone know if it was maplins or has anyone got a link to where I could buy one .....I need to get some pictures off of my old hard drive but don't want to mess about fitting it into the PC case.
TIA
Will this do? You should be able to buy them at most reputable computer shops.
PC_World - Enclosures
Maplin sell them if you just want to get one.
Pretty good as i've sent a few people there for similar issues.
You do pay a bit more but if any of your kids are uni students they get a 5% student discount with their card :)
Those devices are fine if you don't use the HDD more than once in a blue moon to get some data you forgot off it, or if you don't mind having stand alone fans blowing over the drive.
Without the cooling you will potentially cook the hard disk and reduce it's lifetime and data integrity.
I got one of these, which is good for all types of hdd, altough sata drives require an Esata connection on the computer which your eading the drive in (if that makes sense)
Not all sata enclosure need and esata connection. A lot have USB2 headers on them.
I have a Maxtor 4D060H3 that I want get stuff off of ....it's ide not sata and Maplins is the only place to get one quick ....which one is best
TIA
Was gonna say, I've got a SATA enclosure here going spare that I could have sent you, but you've mentioned IDE :(
Steve
If it was my own money I'd get the first box from maplin :)
Not sure if you can still buy the catalogue with the £5 off when you spend £50 vouchers in it.
TIA
Ain't £50 a bit overkill for a one off use :)
If it's a one off.
The reason I'd get the £50 one is that you can put a SATA or IDE drive in it and bridge to USB 2 or e-SATA.
That means any drive you have over the next few years can be used as an external drive to swap between machines. :)
Thanks guys.....picked up one in Maplins last night ......and it works a treat ide and sata if I need it as well ....was very surprised how fast it was ....I was expecting to have to wait hours to get some stuff off
Did you go for the first maplin one and if so did you find any discounts for it?
Glad it did the job.
If you don't need the HDD then you can use it as a permanent external backup device assuming the drive isn't too old.
