1.920v pistons
Just in case someone can answer my question, save me waiting till Tuesday!
I'm looking at 'JE Pistons', but not sure on the size I require......
82.5mm is 1848cc, not sure what size I require for the full 1900cc - 83mm??:confused::confused:
Comp will be 8.75:1.
Cheers,
Steve:)
Found answer = 83mm.
change the crank aswell, get a 100mm throw crank and up it to 2.2 :D
How, where from, and has it been done before.... i'd try anything!
Will be looking into this, a 2.2 20v turbo sounds quite appealing!
Thank you:thumbup:
i am considering this for my current(spare to be) engine :D
83.5mm bore and 100mm crank+gt30 + 4WD = :D:D:D:D:D:D:D
F*CK:thumbup::thumbup::thumbup: That'll be awesome:D:D:D
Copy Cats!!!
first off i need to get my car running with a standard engine, then save up a bit(lots) and get it started :D
Surely a 2.2l with that crank won't rev very high at all :confused:
It won't!!
its not all about revs though, if i could make a lot of mid range torque and actually be able to put it down i'd be happy.
mid-range torque and no revs? is this you coming out of the closet?? :rofl:
if it means a cheapish hand-me-down GT2x, I reckon you should so go for the GT30 or similar :P
Fair point.....
I might just keep it simple and go for the 83mm JE pistons and 20mm wrist pin scat rods, the must be a good reason why very few people have gone down the 'stroker kit' route. 1900cc will do for me:cool:
Mates got Eurospec rods in his Corrado. Very good stuff :)
