1.4 16v MAF sensor location?
Just want to know 100% if part number 7 on the link below is the MAF sensor?
Luke:)
the 16v engine doesn't have a maf, it has a map sensor which measures pressure rather than airflow, it is indeed part 7 on that diagram and they aint cheep
hth:D
About £70 iirc.
Thanks all! I know they are not cheap, I can get discount from TPS so the price isn't to bad!
It looks a pain in the *** to remove! Is it a engine mount off job?
If I remove it can it be cleaned or do they just fail?
Luke :)
First of all i'd just have a look in the inlet manifold and see if its oily.
If it is best take the lot off and clean it all out.
Its very filthy in there! I had the throttle body off and had a look.
Manifold on this car looks easy to remove! Is it a reusable gasket?
