• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Which oil do I need for 2002 diesel
Sign in to follow this
Followers 0
6 posts in this topic
I have a 2002 Skoda Octavia TDi 4x4 (First registered in Switzerland in 11/2002.) motorcode ESW 9102 20 74KW ATD
According to the Halfords page I need 5w30 if I have PD engine, 5w40 if I have not got PD engine but do have variable service and 5W40 if I do not have PD engine but have fixed service.
How do I find out if I have PD engine or not and if I don't how do I find out if I have variable service?
With Pd Eng (from 01\2001 to 12\2002) -5W40
W/o Pd Eng Variable Serv (from 01\2001 to 12\2004) - 5W30
W/o Pd Eng Fixed Service (from 01\2001 to 12\2004) - 5W40
Share this post
Link to post
Share on other sites
Firstly the 5w30 / 5w40 is not the spec you need to be concentrating on, with all VAG engines you need to use the correct VW50?.?? oil the best of the lot is VW507.00 and is suitable for ALL diesel engines on fixed and variable servicing - and has to be used if the car has a DPF (which you will not have)
To check to see if you are on fixed or variable, the easiest way is to see if the car has been serviced every 10,000 miles / 1 year, if it has then you are on fixed, if the intervals are up to 18,000 miles and 3 years you will be on variable, in the front of the service book it will also give you a QC1 etc code - BUT that will only tell you what the car was on when it left the factory!
Share this post
Link to post
OK, Thankyou very much for that for that.
So which VW50x xx is also suitable?
Castrol Magnatec diesel is VW505 00/VW505 01
Castrol edge turbo desiel 5w40 is VW 505 01 / 505 00 / 502 00
Castrol edge turbo desiel 5w30 VW 504 00 / 507 00
So do I have to use the 5w30 cause its 507 00 or are the others ok too?
According to wikipedia http://en.wikipedia.org/wiki/%C5%A0koda_Octavia
1.9 8v TDI Diesel 1,896 cc (1.896 L; 115.7 cu in) 4cyl SOHC [u][b]PD[/b][/u] 100 PS ([u][b]74 kW;[/b][/u] 99 hp) @4000 rpm 240 N·m (180 lb·ft) @1800–2400 rpm [u]ATD/[/u]AXR 2000–2010
Accoring to my manual I have 74kw and engine code ATD so why is it not PD
Share this post
Link to post
You can't go wrong with 504.00/507.00 latest spec vag oils ( any brand like castrol, motul, fuchs...). this latest spec covers nearly all older specs as well. will definitely be great for your tdi :-)
Share this post
Link to post
I appreciate your answer but I would really like to understand what and why my car should have. How can I find out of I have a PD engine? Cause if I have a PD engine I should go for
5W40 which is VW 505 01 / 505 00 / 502 00
1 person likes this
Share this post
Link to post
ATD engine is a PD 100 engine Edited by bazaa
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
