Audi TT Strut brace
Recommended Posts
Has anyone fitted the strut brace from an Audi TT? If so, could you please let me know how you did it as i was expecting 3 bolts/nuts to be holding the struts in but this does not appear to be the case (shows how much i keep thinking of the 80s cars...)
Link to comment
Share on other sites
Take a 8mm drill bit and 6 m8 bolts with 12 washers and 6 nuts. U can grind the brackets off the strutbrace if u want to. Most people do including me. Make sure u paint the exposed metal to prevent rust. That's about it.
Link to comment
  • 1 year later...
You can use rivet nuts I suppose, would be neater and less hassle to remove. However it scared me a bit in case they didn't go quite right and I'd have to correct something. What I did was use the shortest bolts I could get away with and put black plastic dome covers on, looked pretty neat.
Link to comment
so yesterday this happened!  fitted my tt brace only £12.50 bargain!  i did cut the brackets total ball ache getting the bolts held from underneath wheel off job and some twisting of my arm and its fitted..
  • Like 2
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
