VW Side Window Radio Antenna x2 (FM and FM/AM)
KBPhoto
Recommended Posts
I have been successfully using these are FM and FM/AM antenna on the rear side windows of my pre-FL Octavia estate (which only had one radio cantina) and connected to a Columbus with twin inputs.
P/N's: 1T0 035 577 P and 1T0 035 577 Q
post-59543-0-83424600-1412337800_thumb.jpg  post-59543-0-82794200-1412337828_thumb.jpg
These were taken from a VW Touran with no roof antenna / aerial.
You'll obviously have to 'paint' the antenna on the side windows using windscreen demister repair paint (or something else) and attach the wires on the antenna to the painted lines. I can provide a template for the Skoda Octavia pattern that I used.
I'll also include the cables that are as follows:
Short cable: about 2 m, for FM module connects to existing RAKU2 connector on pre-FL Octavia;
Long cable: about 5m, for FM/AM module.
I've just noticed that the white FAKRA connector on the longer cable is not in the picture, so I will go and put that back on now.
Also included is a dual connector which is needed on a pre-FL to make two connections to the back of a Columbus, Bolero or Amundsen should you be retro fitting one of these and wanting to have two discrete inputs.
£35 posted via courier.
Link to comment
Share on other sites
  • 4 weeks later...
  • 8 months later...
Still for sale.
Quite an easy way to get proper diversity radio input for older cars with only one aerial when adding a Columbus or Bolero or Amundsen.
Link to comment
Signal strength is excellent: after all it is a genuine VAG antenna / amplifier.
It will need some for of aerial attaching to it. I created a window based one using window demister repair paint.
As to whether it'll work with an aftermarket stereo or not, I really can't say.
It has FAKRA connectors in and draws phantom power via the centre of the cable from the headunit.
I hope that helps.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
