Recommended Posts
Hi i have a 2009 skoda superb 2.0tdi 170bhp and the car goes into limp mode with check engine and the glow light on. Thanks  :notme:
Here is VCDS scan
                Address 01: Engine       Labels: 03L-906-022-CBA.CLB
Control Module Part Number: 03L 906 022 QJ    HW: 03L 906 022 GA
  Component and/or Version: R4 2,0L EDC G000AG  4741
           Software Coding: 0001078
            Work Shop Code: WSC 00011 888 181093
                      VCID: 7DF11F7F2404B5F6FF5-8028
2 Faults Found:
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 000 - Signal too High - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100000
                    Fault Priority: 2
                    Fault Frequency: 43
                    Reset counter: 255
                    Mileage: 230060 km
                    Time Indication: 0
                    Date: 2001.14.05
                    Time: 16:44:27
             Freeze Frame:
                    RPM: 1219 /min
                    Speed: 28.0 km/h
                    Voltage: 14.21 V
                    Voltage: 14.21 V
                    Voltage: 14.21 V
                    Voltage: 14.21 V
                    Voltage: 14.21 V
000568 - Manifold Pressure / Boost Sensor (G31)
               P0238 - 000 - Signal too High - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 230061 km
                    Time Indication: 0
                    Date: 2001.14.05
                    Time: 16:45:46
             Freeze Frame:
                    RPM: 1265 /min
                    Speed: 28.0 km/h
                    Voltage: 14.14 V
                    Absolute Pres.: 1030.2 mbar
                    Absolute Pres.: 2601.0 mbar
                    Temperature: 10.8°C
                    Temperature: 23.4°C
Readiness: 1 2 0 0 0
Link to comment
Share on other sites
Welcome to Briskoda  :sun:
Fault No. 1:
16497/P0113/000275 - Intake Air Temp. Sensor (G42): Signal too High Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
Possible Causes
  • Fuse(s) faulty
  • Wiring and/or Connector(s) from/to Intake Air Temp. Sensor (G42) faulty
  • Intake Air Temp. Sensor (G42) faulty
Possible Solutions
  • Check Fuse(s)
  • Check Wiring and/or Connector(s) from/to Intake Air Temp. Sensor (G42)
  • Check/Replace Intake Air Temp. Sensor (G42)
Fault No. 2:
16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High Possible Symptoms
  • Malfunction Indicator Lamp (MIL) active
Possible Causes
  • Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31) faulty
  • Manifold Pressure/Boost Sensor (G31) faulty
Possible Solutions
  • Check Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31)
  • Check Manifold Pressure/Boost Sensor (G31)
  • Like 1
Link to comment
I had the G31 code on mine which is exactly the same model as yours also had the same lights on. It turned out to be the actuator on the turbo that was the culprit. Bought one from skoda which cost around £110 for the kit. Replaced and has been fine ever since.
Link to comment
I've had the ' Manifold Pressure / Boost Sensor (G31)' fault code before too, and like Rajakay it was the turbo actuator that needed replacing, at a cost of £118, plus labour.
The seal inside the turbo actuator has a habit of perishing and won't maintain a given position. My car is a 2009 2.0 TDI170CR.
Link to comment
Yes - I had exactly the same issue/fix but was covered under warranty
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
