Kenny R
  1. I believe the lower spec Kamiq doesn’t have rear speakers fitted, so won’t have the fade option on screen. What model do you have?
  2. You did have the wiper arms in the maintenance position so as to avoid hitting the bonnet. Incase you didn’t, if you turn on ignition then turn it off, flick the wiper stalk down the wiper arms raise and park upright on the screen to allow wiper blades to be changed easily.
  3. The Kamiq 1.0 Tsi comes with either 95 or 116 hp, sounds like you might have the 95 hp version, as by all accounts on here, the 116 hp versions are very capable.
  4. Kenny R replied to leckman's topic in Škoda Kamiq
    How old is your car, if new Skoda connect service is free for 3 years. If older the it does incur a cost.
  5. The dashboard icon for headlights on has gradually disappeared on all Skoda model now. The only indication that headlights are on are the infotainment changing to dark mode and the what I would sidelight indicator under the auto symbol on the switch turns green when the headlights are on.
  6. Have you tried resetting the one touch operation as per the owners manual. Open window fully using switch on driver door, once window open press switch again to open, a click will be heard, now close window fully , then again operate switch in close position, again a click will be heard. This should reset one touch operation on that window.
  7. It looks like you have set a speed warning at 20 mph, the traffic sign recognition system should read speed limit signs and warn you as mentioned above if you go over the speed limit. You can adjust how far over the limit before warning in the settings and I’m sure you can set the warning sound level there as well, perhaps you are not hearing the warning.
  8. As does my 25 plate Monte Carlo.
  9. Turning the ignition on with a key or by pushing a button does exactly the same thing. More likely that that method of pushing down pedals and counting doesn’t do anything, especially not reset DSG gearbox. You need VCDS or similar to do that if you really think it needs reset.
  10. I have a 2024 Kamiq so similar sat nav I presume. Have you checked preferences as you may have ticked to avoid certain road types, also if you select quickest route it will divert you round road works, traffic jams etc so may take less obvious routes. Is your map software the latest, believe mine is now on 26.1 so must have updated recently OTA. Also must add I’ve never experienced the problems you seem to be having.
  11. On previous Skoda turning off the rear wiper when reversing option stopped the intermittent rear wiper operation. Just meant you have to flick the rear wiper if reversing, a small price to pay for the annoying rear wiper operating when not required, especially when it does it on a dry rear screen.
  12. https://digital-manual.skoda-auto.com/w/en_GB/welcome
  13. It’s the indicator that phone is in the wireless charger. From the owners manual…
  14. I used the Skoda approved size 17” wheels with 215x65 tyres on both my previous Kodiaq’s. I still have the wheels and tyres in the for sale section and really need them gone as I have downsized to a Kamiq. Name your price if interested.
  15. It is a withdrawal/ cancellation figure you want , not a settlement figure, and withdrawal can be done in the first 14 days with minimal interest, and no loss of any perks from the deal.
