Everything posted by muddyjim
Charging the battery
Probably with the Ctek negative lead connected to the engine earth as per the handbook advice for jump leads?
My understanding is that the battery negative terminal is not directly connected to Chassis on a Stop/Start Yeti - presumably it is connected via some electronic current monitoring wizardry. The procedure for using jump leads is mentioned in the handbook;
Buying used Yeti TSI - Euro 5 or Euro 6 compliant?
Euro5 diesels (or lower) and petrol Euro3 (or lower) will be subject to additional charges to drive into London and some other UK cities later this year. https://www.gov.uk/guidance/driving-in-a-clean-air-zone
- Windscreen condensation problem
Jacking up the Yeti
I guess you could cut a disc of suitable thickness plywood and glue/screw it to the underside of the puck, it would then safely locate in the jack's saddle.
Banging from engine
It seems there was once a problem with balance shaft bearings on vag diesels - but on PD engines as used in Skodas made before the Yeti (that uses a CR engine) was born. https://www.audi-sport.net/xf/threads/2-0tdi-oil-pump-balancer-shaft-problems-the-definitive-guide-audi-vw-skoda-seat.140949/
Cruise Control
Maybe running off Static Electricity
Jacking kit - Anything missing?
Probably worth checking it actually fits your nuts (ooo-errr!) otherwise it makes all the other bits superfluous!
Shopping bag hooks in boot
Won't the AA (or whoever) change your spare for you anyway? If so you have the choice of using them if (for example) you're stuck on a Motorway or DIY if you're on a nice quiet road without the need to wait.
Location sensor oil
My Yeti is set to annual fixed and I can check the oil temp in the maxidot?
Hot Alloy Wheel??
My MOT certificate (performed yesterday) includes on the back the results of the emissions test. It includes the time at which the test was done.
Cracked Haldex Unit
Just to clarify: The DPF (Diesel Particulate Filter) is NOT the diesel fuel filter, it is a filter that filters the soot out of the exhaust gases, and does not normally need any servicing.
Jacking up the Yeti
.. And as that RACT (Australian breakdown company) video shows, even professionals are getting it wrong!
Cracked Haldex Unit
I suppose I was asking a rhetorical question; that recall clearly states it only applies to 1.2 and 1.6 engines....
Cracked Haldex Unit
Is yours a petrol model? That recall only applies to the 1.2 TSI petrol (2wd) Yeti
Rear mounted bike rack
Looking at that rack on this video, it seems you may need a light board?
Colombus Stereo grumble
You could rename Donna to Zonna 😁
Fog lights too low
Do they mean low beam or low intensity? I didn't think there was a requirement to test the beam pattern?
2010 Yeti 1.2 Tsi accelerator pedal
I have read elsewhere that apparently other Skoda models (maybe the Yeti too?) have a safety 'feature' that disables the throttle if the pedal is rapidly pressed down at the the same time as the brakes are operated? I guess if this is true, it is to help prevent inadvertent accelerating when you are trying to do an emergency stop. And I assume turning the engine off and back on resets it. I also read that having this feature means that you can't perform heel and toe braking. I presume it can be disabled within VCDS? This doesn't explain why the pedal went floppy, but it could simply be that having been disabled, it gave an odd feeling?
Yeti Bonnet catch release
Does the external bonnet catch have a cable? I'm thinking the OP is referring to the catch that you access when the bonnet has popped up?
2. 0 diesel Yeti - timing belt or chain?
Wow! I'll just copy that link into my notebook, it might come in useful one day! 😂
