Everything posted by irfant
Heated mirrors
2018 SE-L (Style spec. in some countries), mirror dipping available after coding, using it while reversing.
What have you done to your Karoq today?
https://www.graficar.com.tr/product/skoda-karoq-konfor-seti They ship worldwide, EN version of the website is available. They are using my pics in their website 😃
Key fob battery
2025 (2.5 mm) for sure, changed them yesterday. 2032 (3.2 mm) is thicker
Wiper blade fitment
Just bought front pair Bosch A863S and A331H rear blades, fitted perfectly. (LHD)
Karoq aircondotioning
Check the AC settings, default setting was "middle" in my car, changed it to "high" No problem at 44°C
Stiff manual tailgate
Same here, but its fine since 3,5 years
- Clock doesn't update time?
- Glove Box
Cruise control intermittently not working
Happened couple of times in 3 years, restored after engine restart.
Fog lights gap between light and bumper
drivers door squeaking karoq
I put thin grease layer which stops squeaking at least 3-4 months. I can give it a try, silicone spray next time
The issue is the same, but the source is clear in my situation. There is a black rubber on the door edge of the inner bottom corner. It squeaks when you open the door while it rubs to the car body. I grease it casually
Karoq with Eibach
Not an Eibach, but I've got my H&R Springs and lowered the car 30-35 mm. It did not hurt the ride quality. And better handling, so I am happy with the appearance and riding feel
Funny door action
Probably a problem from the door micro-switch, happened before
Karoq pictures
Just received H&R springs for my Karoq. Probably tomorrow I will get them mounted on service. Before & after pics will follow
SQUEAKS !
Not yet since 2018 May (20K on the clock)
Karoq cornering light - Halogen lamps
The car model is Kodiaq in the clip, maybe it has a different BCM module than Karoq. You can also try with a newer cable
Headlamp washers karoq portugal
Turkey spec Karoq that have LED headlights have washers too
- Plastic film on the side mirrors
Do you mean this? This is dimming feature of the mirror. I took the pic right after driving out from a dark garage. After a while it turns to a normal colour
Karoq plastic textured bumper scratched
Same happened to mine. A bit wet sanding (1000 grit, sanding confers similar texture), cleaning and local spraying with matte black paint solved it. Unfortunately no picture. No one can notice the scratch
Karoq Adaptive LED lights
Here on high beam the main lens moves up a bit
Anyone have this problem?
I removed all of them
Karoq pictures
Nice colour. I thought they were custom painted
