nickytheshaft
Everything posted by nickytheshaft
  1. I can't really say, I will check a usb stick with music to see if it works this afternoon. 9V!!! , your batterie is really dead. I put in a varta AGM a few months ago. It shows 12,8V car off and 14V when driving...
  2. I launched the stock app and it stayed surching for 10 minutes (the time I need to get to the rock climbing). By the way, on my way back I had the FM with my stop and start kicking in and out and it didn't cut the sound as you described. Staring and stopping didn't affect the FM.
  3. Yes it is, I finally sorted out the canbus issue. I didn't connect the second plug... My bad. Went for Octavia 2017. Now it works. Need to figure out the dab now. I will install dab z tomorrow and test again
  4. I guess I have bad karma, nothing is working, no steering wheels control, no radar showing up, no dab, only fm and GPS. I don't know if it is registering the canbus informations. Which settings did you put?
  5. Ok thanks. I just took my son to rock climbing. I will test as soon as I get out.
  6. I need your help... I can't find the canbus settings. Can you guide me? Thanks
  7. This is strange, your frame is bigger than mine. Mine is flush juste over the top if the unit. Either my frame is too small for my car, either your unit is smaller than mine... I must check this
  8. A question though. Once the unit is in place, how do you get it out? There is no space to insert the extraction tools and the clips are plastic
  9. Got my unit at last. 1 it has the mic input 2 it is lacking the usb power on the harness. I will try to install it on the we
  10. Yes perfect sens. Well I hope you get you quadlock soon. My unit is taking ages to get to France....
  11. WAGSTER, could you check if you have power on the factory usb port? The provides cable has 4 pins with Data / ground / 5v. If you have power on the pi,s of the factory usb (as it seems to be provided from the harness) , the solution may be just stripping the wires from the provided cable and connecting the ground and 5V to the data. The cable would then provide only data on the 4 pins leaving the power to be provided by the factory harness.
  12. Thanks, I tried add links, add picture... What do you choose to show the thumbnail?
  13. Same place as you. I removed the unit, the climate control but couldn't get my fingers deep enough to reach the plug https://postimg.cc/xX7t89KX
  14. I got my extraction keys today so I checked my MIB1 usb plug. Same punishment except that it is white. The 5v is also on another sockets. But how the hell did you get your fingers in there to unplug the usb port?
  15. I think I will go for the wired harness, use it as an extension then split the ones that need to be re routed
