Dan13
Everything posted by Dan13
  1. Hopefully it will just need a tighten rather than a new bracket etc!
  2. Not sure if pics will help Tbh! You can move the handle itself up and down a tad passenger front is not as bad but not million miles behind the rears are ok. Got mechanic coming out Tues who said could poss be the bracket that holds the handle on has broke.
  3. Hi guys. My driver's door handle has started to come loose, to tighten it up is it a screw that sits behind a black grommet nearest the inside door rubber? Many thanks
  4. Hello guys. I recently replaced the boot emblem and the grill emblem, and have now bought the vrs boot badge and the same for the grill. The boot looks easy enough to do with some dental floss etc but I have heard the grill is a pain in the arse because you can ruin your grill if you get it wrong. Has anyone found an easy/easier way to do this please? Thank you my briskies!
  5. My apologies I wasn’t looking properly I have ordered both now so hopefully won’t have any issues
  6. The fronts mate for that code is coming up with 80mm which is the rear unless I’m reading it wrong?! I thought the front badge was 88mm?!
  7. Hi mate. And these deck fit without having to cut pins etc
  8. Evening folks. I wanted to fit the newer style badges to my octy estate vrs facelift. I have the following part no: 1st 853 601a Aul front. And 5jo 853 621 a Aul rear. Will these deck fit my car as I don't wanna waste time ordering them to find they don't fit? Thanks guys.
  9. Hi mate. My mechanic had to take the fuel lines off and there was a nut on mine that had seized so it took him a bit longer gettin it off, putting it bk on again was quicker so not really a short cut I’m afraid. I was turning my light off every day depending how much I was using the car. I have a bracket if you are local I’m in reading
  10. Cars all done totally different to drive the power is continuous not in n out like it was before well 😃
  11. This is probably a silly question so your have to excuse me for asking 🤪 but is the gasket the red bit on the manifold that is all ready attached? In the box there is the manifold only no screws etc
  12. Ah ok, I have the plastic one unfortunately they are a bitch to work on as my mechanic said!! Can’t wait to have my car back up and running.
  13. Hello mate. The 2 brackets there are one is for the plastic manifold and the other is for the aluminium one is that correct? Is it worth fitting the bracket I have to my new manifold/ motor just so it prevents issues in the future or would you not bother? I see what you mean with the wear n tear on the motor
  14. My new mani will be here next wk got a good deal from Skoda I paid £484! So hopefully my octy will b back on the road by Thursday/Friday 👍
  15. Yeah some days mine went off like a scolded cat other days felt like it had lost 30hp. I’ve seen the ones you are on about but again I wasn’t sure on the refurb ones as I suppose you never know. Mind you it’s better than the £1000 I was quoted for a new mani and labour!
  16. Sounds like one to avoid then mate, better go for Oem. It’s probably why I had noticed some days a slight lack in power perhaps
  17. Evening folks. So just an update on the above topic. Earlier my mechanic got my manifold off to attach the bracket which I was hoping to solve the p2015 fault code, unfortunately he showed me that mani has 2 cracks in it so now I am looking at a new one. My question is has anyone had a pattern mani fitted and if so what do u think? Thank u guys👍
  18. Ah ok sorted, got somebody doing it hopefully next week so hopefully he can do it that way rather than mani having to come off
  19. Just wondering if anyone knows of an easier way to do this having the plastic manifold? Does the manifold have to come off and the fuel lines surely there is a short cut?!😩
  20. Hi mate thanks for reply. Dame that’s a pain in the a*** I was hoping it was gonna be the aluminium for obvious reasons. My mechanical skills are ltd so will be a garage job or if anybody who lives in the reading area and fancies earning them self’s a few beer tokens more than welcome!
  21. Hopefully somebody can tell me which mani I have?!
  22. If it’s the plastic manifold I understand u have to take it of to do? If it’s the aluminium one it’s a simple job a few bolts? I will try post a pic Lata of the manifold so hopefully someone can tell me what one I have!
  23. I actually had to change my battery in November so unfortunately for me the light does still come on which is annoying to say the least! And knowing my luck mine will have the plastic manifold, a garage last wk wanted upwards of £800 to change the manifold plus labour and wouldn’t hear anything less other than doing that!
  24. Ok il do it tom as it’s p****** down here at the moment. Thank you for your reply mate👍 Just been out in the car and the light didn’t come on once after 4 ignition turns!
  25. I have the same issue but I’m not sure if my car has the plastic manifold or the aluminium one? My car is a vrs tdi 60 plate if anyone can help I would be grateful.
