Drivers front door handle
Hi guys. My driver's door handle has started to come loose, to tighten it up is it a screw that sits behind a black grommet nearest the inside door rubber? Many thanks
Pics would help!
Not sure if pics will help Tbh! You can move the handle itself up and down a tad passenger front is not as bad but not million miles behind the rears are ok. Got mechanic coming out Tues who said could poss be the bracket that holds the handle on has broke.
Probably worth taking the door card off: the handle fixing should then be obvious.
Hopefully it will just need a tighten rather than a new bracket etc!
That is weird only last week my door handle came off when closing the door . Skoda man just pushed it down and it clicked into the bottom half, no screws.
I've had a flipping mare with mine mate! Mechanic came out yesterday n had a look at the handle and said it's just wear so put it back on the car put as he put the lock back on it pushed the holder backwards down into the the door itself 😡 so he took the door card off which was fine but as he took the one off held on with Revits it snapped the cable for the window regulator 😡 so now a bill which was nothing at first is now at £150 he's coming back later to fit the new regulator so hopefully it all goes well wish me luck! 👍
