Alan_P
Everything posted by Alan_P
  1. https://www.amazon.co.uk/dp/B00WN3CF2I https://www.amazon.co.uk/dp/B00N10BPDW Spring deal being claimed fast. £75.86 all in for Bosch pads and coated disks is not bad.
  2. I noticed a similar loss about 5 years ago with my 2.0tdi 150ps. Every 5k miles it dropped max to min. I removed the silica gel pouch from the header tank (partially split) and have had no drops since. I did a full flush with G12evo last year (partial flush previously) and still no issues.
  3. I've been happy with Pagid discs and pads over the years on various cars. The rears seem great over the past 4 years on my mk3 2.0 150hp Superb although I think they are quite pricey for what they are. I tried Bosch at the front and around 2 years ago and they have been great. Less break dust than OEM and the (coated) discs still look great. Bite seems good and no squealing. Cheapest (reputable) place I could fine at the time was Amazon, but you might be able to do better. https://www.amazon.co.uk/Bosch-986-479-932-Brake/dp/B00N10BPDW https://www.amazon.co.uk/Bosch-BP1505-Certified-Copper-Free-Accessories/dp/B00WN3CF2I Make sure it's from Amazon direct and not a third party seller if you do go with them.
  4. It's the wheel lining that needs to dropped down. You could take the headlight unit out, but that's a lot more work and not necessary. Check the post for full details. Dealers can supply the cap, same as the one just beside it.
  5. It's one of the first things I changed when I got the car. I hated how yellow the DRL bulbs were, even compared to the factory H7 bulbs. This excellent post from @SJCSE details the procedure of cutting the unit and once done, the cap fits perfectly: https://www.briskoda.net/forums/topic/379864-se-and-se-business-drls/#findComment-4456863 I've since gone through various PW24W LED options, but the only ones I found close to the Osram Cool Blue Intense H7 I use (just road legal) kept giving errors. I ended up going with halogen bulbs that are very close and obviously give no errors. It's the blue tint version listed as "white": https://www.aliexpress.com/item/1005002462773625.html Working perfectly for 7 years. EDIT: I remember having to shave a tiny amount off the leg of some bulbs, just to get a perfect fit.
  6. Around 4 years ago I removed the silica bag from the expansion tank on my 2017 2.0TDI 150ps. I was planning to do a partial flush using G12evo, but I spotted a bulletin stating that EA288 must use G13 (see attached). It does say US only and there is separate conflicting info on what gen of EA288 it applies to (not just CVCA/CRUA). Does anyone know if it applies to the J623-CRLB variation? It seems that G13 is VIN order only.
  7. @Itsrelfy do you use auto hold? If so, try disabling it and go for a test drive.
  8. https://www.google.com/search?q=vcds https://www.ross-tech.com/vag-com/VCDS.php I've changed from "Normal" to "Early" for the IDE05055-Hydraulic brake assistant. No obvious or immediate change, but will give it a proper test tomorrow.
  9. Will give it a try 👍
  10. Do you know if this works for a manual or is it just for DSG cars?
  11. My 2017 2.0 150 takes the 5Q0127177 (ufi 26.038.00) (mann PU 8028).
  12. I had a constant, slow drop in coolant until I removed silica bag from my (single wall) expansion tank. I removed it to stop a future matrix blockage so it was more of a happy side effect. I thought I burst the bag slightly when removing/forcing it out, but maybe it was already leaking.
  13. @xman Load transfer is yet another variable which actually supports having as balanced a set of tyres possible. It’s also not the only thing affecting load, grip or the distribution of traction. If you’re suggesting it’s the only factor or somehow mitigates the use of mixed capability tyres, we will have to agree to differ, again. You posted some info from Michelin so hopefully you accept their findings and not only when it suits. Have a look at the “Can you mix winter and summer tyres” and “Fitting different tyres on the same axle” sections: https://www.michelin.co.uk/auto/advice/choose-tyres/mixing-tyres Here is a little safety video from them with a demo covering traction and inertia (some other variables): https://www.youtube.com/watch?v=BaXXrKFJctU Anyway, I’m complicit in continuing to hijack this thread and this is my last post. In some areas it has degraded into providing anecdotal, singular driving experiences as evidence. Written statements of bizarre “testing” and brake checking people for tailgating is certainly evidence, but not of the type that was intended, I think.
  14. @J.R. and @xman I don’t know how else to explain it, but I’ll give it a try with a simple example: Hopefully everyone agrees that given the same conditions and speed, a car of a fixed mass generates a set amount of lateral force when taking a corner or bend in the road? When tyres with the same amount of grip are fitted, this force is distributed (relatively) evenly and the work is split. In this scenario, when the car starts to lose traction, the mass is distributed anywhere from 60/40 up to 50/50, front to rear for most modern cars. With the outer tyres doing more of the work obviously. When tyres of mixed capabilities are fitted, this same force is distributed unevenly at the point of losing grip. What was previously a relatively even share of the work has changed because the tyre with superior grip is nowhere near losing traction. The tyre(s) with lower (weaker) grip now has to deal with more mass and loses traction faster than it would do previously. A sort of pendulum effect. Bumps, potholes, and spillages on the road can further exacerbate the issue. You guys are obviously experienced, well above average drivers so this only applies to other road users. When I mention mixed capabilities, I’m referring to winter or all-season tyres mixed with summer tyres. Apologies for using industry accepted “summer” terminology. A full set of “summer” tyres is safer than mixing winter or all-season tyres with summer tyres during winter conditions IMO. I’m more than happy for someone to actually explain why they think this is wrong, or I suppose you can just call it “nonsense” and “tosh” again. As I said before, it’s probably best that we just agree to differ, especially as one of you seem to think winter tyres, or their benefits, are a myth.
  15. Yes, as I said, I think it’s safer than running mixed tyre types. Having winter tyres on the front and summers at the rear might get you up an icy driveway easier than a full set of summers, but handling and braking is negatively affected on the road. Not to mention keeping ESC sane, if and when it’s needed. Just to clarify, mass loads up on the weaker tyre(s) and causes it to lose grip even faster than it would do normally. Not only are you unbalancing the car, but you are making a poorly performing tyre even worse than it would be normally. You might get away with it, but increasing braking distance and creating oversteer or understeer where it didn’t exist before is not advisable IMO. I don’t have access to the stats, but maybe people running on a space saver for short periods is safer overall than those who don’t have a spare and sit at the side of the road or even block a lane while they wait for recovery.
  16. It’s probably best that we agree to differ with regards to mixing tyres. I consider having winter/all season tyres at the front and summer tyres at the rear (or vice versa) at temps below 8c to be dangerous. Even worse if it was mixed across an axle. The mismatch in performance and grip is much worse than having summer or winter tyres all round IMO. I appreciate you're an advanced and experienced driver who can dramatically lower your speeds and increase braking distances, but I personally prefer my car to brake and steer as well as possible instead of driving around a safety issue I created. Especially when I can’t moderate how other road users drive around me. This is before we consider ECS/ABS implications or having to convince an insurance assessor that an accident wasn’t due to a mix of 3PMSF and summer tyres. I sometimes borrow a fiends mk2 Capri for a nostalgic Sunday drive. It takes me back to my teens when I had a 3.0s on barely legal 30yo tyre technology. Roundabouts in the rain were hilarious, but I don’t want even 10% of that for a daily driver now.
  17. I think the original CrossClimate are perfectly suited to the UK weather. It depends on your usage, but the CrossClimate 2 swings back a little too much to ice/snow grip with a loss of general handling IMO. It might indicate they going to push the Pilot Sport All Season 4 to the UK, which would be great. In saying all that, I feel CrossClimate 2 is still the best option overall. I often see comparisons people make with the absolute best winter tyres and the very top performance summer tyres, but are these people also swapping back and forth several times a year to enjoy these gains? We’ve had weeks of double figure temps followed by weeks of 4-6c during the day since the start of the year in Scotland. I would prefer to be on a CrossClimate than a Pilot Sport at 5c or a Pilot Alpin at 15c. With the UK temp swings in Winter/Spring/Autumn, you would have to be pretty active to be on the perfect tyre at all times of the year if you swap between winters and summer tyres at every +-8c change. I've seen posts from people slamming all season tyres who still run the older factory Cinturato P7 tyres. Check the stats of your summer tyre before hating on all seasons: https://www.tyrereviews.com/Tyre/Pirelli/Cinturato-P-7-Ecoimpact.htm https://www.tyrereviews.com/Tyre/Michelin/CrossClimate-2.htm Video review including Pilot Sport All Season: https://youtu.be/421HkK4Nqss?si=ChXsGoHBH-nT8VOs Sorry for the hijack and not much use to the OP, but I was following the all season talk. CrossClimate are expensive and you cannot gradually change to all season. I personally wouldn't like to mix tyre brands, let alone a dangerous mix of summer and all season. The Tyre Reviews channel I linked above has good reviews of the best budget tyres though. Hankook always seem to do well with price to performance.
  18. I retrofitted the camera and discovered the issue. I used an OEM camera and it’s supposedly the same connections used when factory fitted. I’m sure my removal and (initial) reconnection contributed in my case, but it took a year after fitting to happen and it’s a really easy thing to try. The glovebox pops out/down very quickly and you can reach up to the quad block at the back of the head unit. I’m not sure about the dealer relevance, but I had a constant fault and it was easy to diagnose/fix. If you have an intermittent issue, the dealer might not be able to do much unless it’s creating a code.
  19. I had this issue a while back and the blue block on the head unit connection just needed reseated (above glovebox). It’s been fine for over a year now:
  20. Mine are still working with no issues
  21. Understandable, but I just wonder if it could also be contributing to premature water pump failure. Maybe blocking the matrix or the abundance of silica damages the seals?
  22. Have you checked if it’s burst/leaking? Unfortunately you can’t check with some double walled tanks, but I just wonder if a leaking bag can do more damage than blocking the matrix.
  23. Can I ask anyone who had a pump failure if you previously removed the silica bag from your expansion tank? If not, did you notice if it had split?
  24. That’s strange, almost the reverse of my situation with lower voltage but good cranking amps. To be fair, I never get the slightest hesitation at turnover even in cold weather or any errors. I also never use start-stop though. An AGM should perform better than a standard battery in cold weather so it might be a good candidate for a charger than has a desulphation cycle or at least a recondition mode. I resurrected an old Clarke 900 jump starter with a Ctek MXS 5.0 about 6 months ago that was refusing a charge from another smart charger and the simple Clarke charger. IIRC the Ctek was in the initial desulphation cycle for about an hour before going on to fully charge it.
  25. I just tested with bonnet open and then closed and there is no difference. Both give a reading of 12.43v after the car hasn’t been running for nearly a week. It made me question the reading on Tuesday (12.3v) so I tried another multimeter and it gave 12.44v so well within tolerances. It’s not a permanent drain given the reading today so I either didn’t lock the car or didn’t give it a full 30min on Tuesday. Anyway, it seems much better than the ~12.2v I was getting prior to the full recharge and battery reset. Thanks for all the info and I will keep an eye on it.
