Everything posted by sakta
Volf's Mk3 VRS Wagon
As in you overheard it on a dash cam recording when they had your car mapped? I cant think of any criminal offences it fulfils so I'm not surprised they haven't responded to a letter, no crime was committed. Not malicious communications or harassment. Sorry to say but that sort of appearance, most people are going to think negatively of you.
minimum requirements to start reading/checking car maps and flashing new maps via a laptop?
Yes, you would use a bespoke tool designed for flashing, for example KESS or KTAG. For very old cars you can use a very cheap Galletto cable. Reading the map is only the first stage, the second question is how to actually access and change the map - this is the incredibly difficult part Maps are literally just hexadecimal - the numbers 0 to 9 and A to F. To be able to take nothing more than this and turn into something understandable you need software for remapping, I.e Winols. For the old diesels that had a EDC15 ECU, there was a free tuning program, that in combination with a free 1.9PD tuning guide online, would quite easily let you experiment with tuning at home. I had a Fabia vRS that I would constantly tune and then log and then tune. using a website like ecuconnections you can have other people review your map and give an opinion pretty much all ECU programming software is expensive and even then you are not done, you need a DAMOS to be able to identify all of the maps on the ECU and adjust the values. sure, you can purchase cheap maps online, but most of them are more of a decalibration rather than a performance remap. A lot of people think they are getting something decent when they go to a place with a dyno, but most of the time they take a generic map, make very minor changes and then call it a custom map, a proper custom map takes hours of work if you are only interested in improving your car rather than getting into tuning, then the best option would be to go to someone like Celtic tuning that can come to a home address or work and flash a map. REVO are absolutely brilliant so if you have a local dealer, they are the best option.
Racing Line have a very good reputation on the petrol, no idea about the diesel. Got mine mapped by Revo a few days ago and I’m shocked at the difference it made, it’s night and day. If you get the Revo DSG map, they change the shift points to keep it in the power band after the map, amongst other things
Octavia VRS 194bhp Remap
Just made a booking to have mine mapped, next week on Thursday before the REVO offer ends. for reliability, there is nothing different about mapping an Octavia to remapping any other car. You are putting more wear on your turbo, clutch and flywheel. If you drive it normally with the occasional hard pull, you will not make any substantial difference to the lifetime of the car. If you are an aggressive driver, then the difference will be noticeable. If your car is already close to, or at 100K and you have an aggressive map put on, and then spend all day with your foot planted, then you could very easily kill the turbo in a few thousand miles. At the end of the day REVO have access to more cars and have more staff and tracks to test their cars on than most tuners, and have likely covered far more miles with the software on than other tuners, to make sure it’s reliable as for the common oil burning issue, I changed the oil for Liquimoly TopTech 4200 and added some Ceratec. I haven’t burned a drop in the last 3-4000 miles.
Tuning and mapping
Just like mechanics, most tuners are clueless and either flashing a poor quality generic map made by someone online, or changing 1/3 of the individual maps they should be. Even the companies with a proper rolling road don't do a good job half the time, even if the vehicle makes more power - it doesn't mean it is done safely or properly. REVO is one of the best as they have a large team and test their tunes on lots of cars before approving them and selling them. They also let you choose between low and high boost depending on if you want longevity or power. If you don't have a nearby reseller APR are not bad either (but known for aggressive tunes killing turbos quickly), RacingLine are worth considering as well. Revo quote £480 to increase power from 184ps to 217-236 ps (depending on boost you select), and from 380nm to 468-515nm. I believe it shaves almost a second off the 0-60, a petrol will always be faster but the map does make a marked improvement.
Car crabbing after rear end falling in ditch
Awfully embarrassing! The front tow hook was at home not in the car which is why it was towed out through the control arm (oops!). I went to a local tyre place for an alignment, they pretty much said we don't want to take your money as we doubt its an alignment issue, so going to the mechanic tomorrow. Part of me hopes it is suspension damage so I have an excuse to fit my coilovers the car is in need of some work at this mileage.
This is rather embarrassing, but I forgot to put the handbrake whilst at a car park, and the rear end rolled into a ditch. I tried to drive out but the front wheels both spun as it was muddy. The AA man ended up hooking up a strap to the bottom of the front control arm. Now the car crabs and it skips bumps (the rear end swerves right a little). Is this something that can be solved with a 4 wheel alignment, or has it falling into a ditch likely bent the chassis and its now a write off?
Piper Exhaust Question
From photos the diameter on the bends is slightly smaller but not by much, maybe 5% or so I would imagine. Its not bad at all compared to cheap chineseium boost pipes where the pipe is almost half the diameter at a bend
Fabia Mk1 Vrs vs Ibiza Cupra Tdi
FMIC will make it spool a little later. So around 2500RPM. But again at this age expect boost leaks which will affect power. That and the possibility of a bad remap making things worse. Most remaps for our engines are poor and not really on the dot. So it will bring out mechanical issues even more
Yet Another Fabia Temperature Gauge Problem!
Its best to make your own thread. This is for the mk1 Fabia, but the fix should be the same. Unstable temperature, always change the thermostat
vRS loose steering
So far replaced Both wishbones Both control arms ARB Links Ive attached a video of me moving the wheel back and forth. There is play and it moves an inch either way. When I turn either way, there is clicking coming from the left side. When I accelerate hard, it pulls hard to the left as if most power is going there. If I go over a bump, the steering jolts, and the motorway the car veers left and right. The steering also doesn't return to center most of the time, and when you are almost at full lock it almost 'falls' into place. The tyre is also VERY worn on the outer area near the side wall, and slightly worn on the inside. IMG_5750-1.mov
Octavia PHEV 204ps
I very much doubt it is just software. But for sure you can get a remap/stage 1 once a company like Revo has made one, which should increase the other two somewhat
New vrs, new issues
Well, the thing is, it can make 220hp or so. But you need a front mounted intercooler, PD150 headbolts, 4 Bar MAP Sensor. Do you have those? If not, then no real point getting a remap, because you won't be able to make any use of the turbo. So you have to make sure you have those sorted first before anything. I post on a tuning forum now and then, where people post their own maps for review, and some maps that people have paid for are absolute ****. A good map is hard to do, and a lot of tuners make silly mistakes that will kill your turbo quickly by pushing too much boost, etc. Most common mistake is just bad tuning that will make it run rich and make low power, but again the turbo is only thing that can really fail As sepul said, plenty of maps available from map suppliers. So you could in theory buy one and flash it yourself.
vRS loose steering
I've recently done a lot of repairs to my Fabia, quite a lot was wrong... Fitted new control arms (with new console bushes etc - they were knackered), new ARB links, and the steering is tighter. But, there is a lot of play in the steering, when you go over a bump, you get a loud thud in the car, and the steering shakes. My mechanic has looked twice, and he still can't find the source of the problem. If it helps, when I turn, I get clicking so assuming my CV joints or driveshafts are on the way out, but I assume this is a different problem? On an unrelated note, I get a weird intermittent whistle, seems to be around N75 area. Its a constant frequency, doesn't go up and down according to boost. But it starts as soon as boost kicks in, so around 2200RPM+ - really worrying me, its not that loud at all but unsure what it could be?
Recommendations for tuners? - Fabia VRS
I wouldn't go to Darkside. They aren't such good tuners, great hardware, but bad quality tunes, terrible torque spike that kills clutches and DMFs. They also set an aggressive popcorn limiter/launch control that reduces the lifespan of the turbo and injectors. At 60K miles your Fabia holds quite a bit of value, so you'd want a safe, reliable tune I'd check Celtic Tuning, they can come to your door and map it. PD Hereford also seem to know what they're doing judging by their Youtube comments. Spike at 2240RPM which makes no sense.
1.9 TDI BLT No power, cant rev over 1400RPM
When I bought the car originally it drove fine, had normal power and was remapped. No problems at all till joined a motorway with launch control which made the turbine blow. 1st replacement turbo (now failed) - car was burning oil and down on power with this fitted. Gradually it got worse, sometimes it would enter limp mode and not run on boost at all, sometimes it would make a loud weird whining noise, which was fixed by turning car off and on. The new, currently fitted turbo was fitted at the same time as the EGR delete, was fitted by mechanic so unsure what was done but confirmed that he did blank off the EGR port on the turbo I've tried both the original map, and a new map where I made some changes, both with and without the EGR deleted, as well as disabling MAF so it runs purely off the ECU map. In all cases nothing changes, it stayed the same
I plugged the only one that was removed, being for the EGR which is labelled "2"
Sorry, another topic, again... but seeing as some like Wino, sepul know more than any mechanic around here does, Ill try My original turbo failed at 170,000 miles. Since then, I've had it replaced, and after the replacement the car was clearly down on power, and burnt oil, still drove though. That turbo managed 15,000 before failing (cheap used ebay jobbie) I've replaced the turbo again with a refurb one, cleaned out the intercooler pipes from all the oil the old one left when it failed, deleted the EGR and anti shudder valve, but now the car has literally no power. It can't rev above 1400RPM or so, is a little smokey and if I press the pedal down further than 40%, I get a knocking sound from the engine (see video attached). Doesn't seem to be any boost leak as there is no air whooshing sound It seems to idle okay, every 10-20 seconds or so it feels as it if just about to die though. My car has been parked at the mechanics for a week, he is far too busy and claims issue must be software as I deleted the EGR, but there are no error codes for the EGR, just the ASV valve. What could it be? Only thing I could think of was the N75 vacuum tube as the mechanic didn't block it initially, but that's been plugged and no change 62507258557__44EF205C-D3B2-4634-964D-998E465321B9-Up to 4K.mov
Can I fit an ASZ turbo onto a BLT?
Okay, ASZ turbo fitted and EGR and ASV are Deleted. Now the car starts and idles fine, but is not boosting and being smokey and doesn’t have enough power to drive. No error codes on ECU Any ideas? I remember someone mentioning adjusting some sort of screw on the turbo - VNT rod adjustment or something? Mechanic has no idea
None. Your car is non turbo so you’d need to spend minimum over a grand to fit a turbo, it would take a ton of work to completely overhaul the engine so it doesn’t blow up from the added power, tune it etc want more power? Buy a different car, that engine is far too basic and small to do anything with
Going on from my other post looking for a BLT turbo..... can I buy an ASZ turbo, install an EGR delete, and then fit an ASZ turbo straight onto my BLT engine without any modification? As I understand the EGR is placed differently on the ASZ but otherwise they are identical
WANTED vRS BLT Turbo
Does anyone have a breaking vRS with the BLT engine that is selling a turbo? Mine has gone, and options on eBay are limited and pricey. TIA
Picture heavy guide to converting mk4 golf (recaros) seats for a fabia.
Works absolutely fine, theyre identical, youre doing something wrong. I did mine a month ago and they are identical bases
Mk1 Sleeper, is it doable?
No point for the 1.4, nothing you can do to make power without pouring tons of money in.
Was just going for a Revo, when.....
REVOs tunes are great but they don't specialise in diesels. There are other companies that will take into account the stock clutch and limit the torque as they see fit so you dont have clutch slip. Remapping does mean your clutch will go out sooner regardless as will the turbo and dreaded DMF. If ever going for a map, avoid launch control too, that is aggressive and can kill the turbo, as I found out to my demise. "Popcorn" limiters also can cause damage but not as serious.
