beezera10
Everything posted by beezera10
  1. The plastic block can be a bit of a bugga, but I think it's clipped onto the sides of the battery. Ease them back and it should pull off.
  2. Thanks! I'll clean it a bit more and see if there are any tell tale signs. Difficult to get to to see without a lot of dismantling.
  3. 2008 Octy 1.9Tdi PD 1Z5 BXE oil leak. I've removed the plastic pan, cleaned everything up and inspected for wet areas. The leak doesn't appear to come from the rear or bottom of the engine, or from the left hand side of the engine (fuel filter side). The tandem pump at the top doesn't appear to be wet. The leak appears to be higher up the engine and just below the oil filter housing where it does seem quite wet. The oil filter housing isn't leaking (from the top, at least). I know how difficult these things are to locate, but wondered if anyone has any pointers. The oil is definitely engine and not gearbox. Any suggestions and possible fixes/checks would be welcome.
  4. BXE is fine. My 2008 BXE Octy is on 185K and sweet as a nut. The car is only worth about a grand, so if it blows, it won't owe me anything. Still on original turbo and second DMF went in about 20k ago. Timing belt every 60k. 507 Mannol oil every 10k. I know some have worried about Mannol, but I've used it for about 15 years with no problems whatsoever. Been used to pull trailers and caravans, a lot of short work (no DPF). I did have a 2000 Octy with ALH engine. At 158k it was very smoky, had a problem with one of the solenoids (wouldn't start at times), needed a clutch and timing belt, so sold it for £350 to get rid. I had about 30 phone calls, and the geezer who collected it was an Eastern European from Bradford. It's probably still being used as a taxi even now.
  5. You're right, and I have used them before, excellent then also. They're about 3/4 mile from me, so I could run the car up and walk back (didn't want to risk a garage further afield and get stranded). Considering the MC went around lunchtime Sunday, and the car was back on the road 3.00pm Monday, that's a pretty good turnaround. If anyone wants to check the garage out, it's West Street Garage, Normanton, West Yorks. If you break down whilst passing through, or near, Normy, and you can only be recovered locally, this may be an option. Reviews are online. Excellent customer service, very fair prices, quality parts, very little not to like.
  6. All fitted in time to collect the missus from work. Item was Luk branded at ca. £69+vat. Labour was £60+vat per hour. I made a point of speaking to the mechanic and, when asked about the make of cylinder, he said 'we don't fit Ebay parts here'. As someone who has often bought cheap and bought twice, I agree with him. First master cylinder in 182k miles - AI reckons about 2m operations😲
  7. I'll post back when I find out which brand of master they used. If it's Sachs, Valeo, Luk, etc, then fair enough. I have to bear in mind that there's an insurance that goes with the work - if it goes wrong it's straight back to them. If it's me doing it, it's all on me!!
  8. Fair enough. How easy is the slave to do, and what's the bleeding (of the fluid!) procedure? TBH, I do most things on the car but I really don't fancy awkward jobs that require scraping under the car for too long. I still have the ARB bushes to do, when I can, but the car's in almost constant use so I can't take it off the road for long. That's why I'm happy to pay the £227 if it means I only lose one day!
  9. Thanks for all your help, much appreciated. I took it in to a local independent who diagnosed the master was failing - £227 for replacement and fluid change. Seems a bit pricey, but it's not a job I have time for or fancy. Having said that, I took it up to them this morning and they said they'd have it completed today, which is a bonus as it's a car we can't do without. I think you're correct about the slave, although I'm told that's not an issue. Strange the no new grommets or seals come with the new master though, I'd have thought they'd be important to renew?? As for fluid levels, I think they were ok. I found it difficult to check as the reservoir is a bit opaque. Usually, I try to shine a bright torch through it to see if I can see the level, but not sure how accurate that is.
  10. Probably been done to death elsewhere but, here goes. On a brief journey out, the clutch pedal went to the floor. Got an anxious call from the wife and got over there. Pedal was stuck to floor, but giving it a tap it released and I drove it home (pedal was spongy but recovered with a bit of pumping). At home, the pedal worked fine for a couple of dozen engage/disengage. So, is it master or slave cylinder and, if the latter, is it located in the bell housing or outside. It's a 2008 Octavia Mk2 Tdi PD 1Z5 estate with BXE engine (5 speed). Any clues to possible cost from an independent? Cheers all
  11. I have a 2008 Octavia 2 with BXE engine. Just topped 180,000 miles in it with no issues whatsoever. Serviced every 10,000 miles without fail with 504/507 Mannol oil, sump drain not dipstick pump. Engine is sweet as a nut, on original turbo and EGR. Only engine replacements are clutch (first one) and timing belt every 70,000 miles, also thermostat and engine coolant sensor. Car did go into limp mode when thermostat was failing, but all back to normal now. Of course, if it does blow, it'll go for scrap. Its now 18 years old, battered round the edges, and has that mileage on it. Oddly enough, I found out a couple of years after I bought it that the original owner sold it because he was worried about these horror stories. Car bought for £4.5k privately in 2015 with 74,000 miles on the clock and in really nice condition. N/B Warning re clutch, I originally went for a SMF conversion, which proved to be a disaster (slipping after 30,000 miles). I went for a refund from the warranty (2 months off 3 year expiry), and got half the cash back (£300). Reverted back to Sachs DMF (which cost less than for the SMF conversion at £550!!). I now have my car back and driving perfectly.
  12. I would definitely get a diagnostic on the electrical problem. Like you, I reckon electrics are a dark art and 'earth fault' is not far off torching the car and buying another. You'll know when the pulley is on the way out when the belt/pulley starts screeching at you. When I released tension on the V belt and tried to rotate the pulley, it actually moved up and down and was very stiff. On removal, most of the roller bearings fell out and the cage had partially disintegrated. If you do replace, put a dab of grease around the bearings - helps keep the moisture out. My old one was dry as a bone and a little rusty too. Good luck with those electrics.
  13. Quick question on the plastic dipstick funnel - why is there an L shaped tab on it?? Re removal of broken funnel. In order to prevent bits of broken funnel disappearing down the tube, I left in the rubber hose with plastic bung (used the cap off a clean sealant cartridge nozzle). Because I couldn't get pliers on it, and wanted to avoid marmalising it any further, I then got a hooked piece of thick wire, and pulled on the L shaped tab as near to the broken tube as possible. After a few goes, the internal remnants shot out in one piece (thanks to the rubber hose/bung keeping things together), with just the outer left. This just peeled off easily. I've done my best to shove the new one on as tight as I can get it. It seems to have located on the collar of the metal tube ok. Will have to see if it decides to stay on after a few runs??
  14. Decided to replace the thermostat as well. All sorted now. An account of it is on the VW TdiClub Forum under Mr Nexus.
  15. Sorted mate - air lock in heater matrix. Funny, I've been driving for 50 years and never had a thermostat or head gasket failure (nor EGR cooler). Temp is now bang on 90C, and vents push through hot air at all engine speeds. Looks like the old stat had had its day after 180,000m and 18 years. Engine's a BXE.
  16. Nice one. At the moment, I've got a bit of rubber hose stuffed in there with a plastic cap jammed into it. Will stop any oil for now so the car can be used. My Octy's worth about a grand, so not wanting to spend a fortune on it. Any thoughts on bleeding the cooling system so my heater works properly? Hot at higher revs, cools off at lower revs with engine at 90C. Top rad hose is hot, bottom is cool so thermostat is working fine.
  17. Cheers, much appreciated. I did think about the sleeving option - what did you use as a sleeve? In any event I've ordered a replacement. I'll pack the hole with a rag and try to ease the remainder out with long nosed pliers.
  18. The dipstick funnel broke off whilst fitting a new thermostat (just knocked it and it broke at the base). Any advice as to how to replace. My understanding is the bit at the bottom will pull out and a new one pushed on. Is this the case or is there a hidden screw somewhere!? Also, after replacing the stat, I can get it to temp but it only blows hot air at higher revs when stationary. I'm guessing that the heater matrix may have air in it. If so, any suggestions as to how to bleed the system thorougly. I've left the reservoir cap off and put the heating on full so far.
  19. Just a note. If your alternator freewheel pulley has gone (mine disintegrated), then with a cheap, splined tool and a long hex/torx set (can't remember which), you can just replace the pulley. Did mine in about an hour or so. Just relieve the tension on the V belt (obviously). Only the removal of the fuel filter housing is required (undo and set to one side without disturbing the filter). Really simple job and cost around £25 for the pulley (I used a Gates item), and a few quid for the splined tool.
  20. Quick addition to this topic FYI. 2008 Octy 1.9Tdi PD 1Z5 BXE. After a 100m drive in cool conditions, the temp gauge wouldn't move past 70C. Got home fine. A couple of days' later, car went into limp mode, but no lights on dash. Temp gauge was stuck at around 65C, but would be a little erratic (rising a little, then dropping a little). Decided to go for coolant temp sensor replacement initially, as warm air was coming through the vents (indicating no thermostat issue). Replacing the sensor was easy, only requiring the removal of the air box for access. Removal of battery, etc, was not necessary. Replaced with a Hella sensor - £11. After clearing the codes, the car is off limp mode and heats up to 90C after a drive and some stationary fast idling. Cools back down to around 75C on very cold days (like today), but increases when stationary. Had no dash lights at all at any point. One thing I did forget to do is to clamp off the coolant reservoir to minimise fluid loss. Fortunately, I had plenty in!
  21. 180,000 miles on my 2008, no issues whatsoever. I think the whole BXE thing is overblown, and I don't worry about it.
  22. Thanks mpm222. My query was with the stated instructions from Powerflex (above) about drilling out the swaged section when replacing on an Octavia Mk2 and similar. If the Mk2 hasn't got the swaged fixing, then the procedure would be fine (I'd also use longer bolts initially, then remove one at a time and replace with the correct bolts). The bush assembly should be held in place long enough for the original bolts to be inserted. If my Octy has the swaged assembly, I was wondering if the whole bush could be moved to where there was more room. If so, the bush could be rotated to drill the swaged section or the front clamp could be cut off completely. There are kits out there which supply the clamps as well as the bushes. As I've said, I've not looked at the job closely as yet, but I'm keen to cure the clunk and rattle on mine. Thanks again for your input!
  23. Just a thought, but is it possible to remove the bolts on the bushing, knock the bushing assembly to one side, rotate and drill out the swaged section in situ to remove the brackets and bush. Reassembly would simply be a reversal of the process. Of course, there may be a number of reasons why this can't be done (mainly room to rotate the assembly) but, if it can, it obviates the need to drop the sub frame and/or remove the ARB. I've not looked at the arrangement closely, hence the question to those that have done the job.
  24. https://youtu.be/wI4nq_4bZlg This is for the Mk1, still looking for the Mk2 but I'm told they're similar?
  25. Autodoc video seems to suggest the bushes can be changed without lowering the subframe. A bit tight but removes the hassle of throwing the subframe out on reassembly.
