Everything posted by westie38
1200 mile Covid Service
And, complementary damaged rear parking sensor.
Poll for water ingress into cabins
4th Option is leak in to drivers footwell from joint between inner wing and bulkhead. Skoda Colander- Simply Soaking!
Door reflector wiring
Have a read through this thread in the Karoq section: INSTALLATION OF THE WELCOME AND EMERGENCY LIGHTS (RED) OF THE FRONT DOORS. Really easy mod to do
What's this? (mobile related)
If you have a phone that is capable of being charged on a pad, simply lay the phone down on the pad (back side down to the pad), and with the engine running you should get a message on the infotainment screen stating that the phone is charging
Any reliable 3rd party adaptor for wireless car play?
No, I meant the built-in charge pad under the sliding cover in the centre console.
Not particularly, mine has the original charging phone box and signal amp. At the moment I still have an iPhone 7, so it doesn’t charge on the charge pad, although my wife’s 8+ still fits on the pad and charges even with the CarPlay device fitted. Boot up time takes around 40 seconds or so.
I’ve been using a Carplay2Air for a couple of months now and it’s been a great success. I bought a 90 degree adapter, and it fits brilliantly under the sliding cover in the narrow channel within the phone box. It’s held in place with a strip of double sided tape so that the lid slides shut properly 👍
NEW MYSKODA APP - DEC 2020
Richmix, I use Apple Carplay and I always have Google Maps running. The only time the maps zoom in (and then zoom out) is when I come up to and pass an intersection. Even passing under a bridge with a road above will cause the maps to zoom in then revert back to normal view. Otherwise, no problems at all. Incidentally, I run Apple Carplay wirelessly using a carplay2air device. Regarding the 'new' MySKODA app, what a p*** poor effort from Skoda wherever it comes from - why disable a working feature until the new one is up and running correctly! Yet again, Simply NOT Clever...
Water Ingress - Passenger footwell
Ray, if it helps, get them to ring DM Keith Skoda in Hull to ask for any information regarding leaks and/or missing sealant. That's where I took mine to have the problem rectified - which included replacing all the carpets and underfelt (all done under warranty), so they are fully aware of the situation. The worrying thing is that water ingress for any reason is not covered under a warranty extension (my Karoq is out of warranty next month and I have just had the offer of extending it.
All this doesn't bode well for the future ownership of my Karoq. I didn't realise there were so many similar threads to this problem - I posted my experiences of this in July in the Campaign 60E3 thread. What worries me is wether Skoda UK will honour the repairs done under warranty when my particular Karoq comes out of warranty next Feb. When you say your repair was done by a specialist body shop, was there any reason your dealership didn't attempt the investigation and repair?
Is yours getting slacker as it's getting older?
Ha, now I've got your attention. For all Karoq owners out there with the retractable load cover/wind break/partition cover, I was wondering if you have noticed if the cover retracts fully if it's unclipped from the tailgate? My Karoq is coming up to two years old now and I've recently noticed that the last 4 to 6 inches of the cover just hangs there. Following on from Silver's post regarding the similar situation with the Kodiaq load cover I tried to lubricate the mechanism at either end of the load cover body, but it hasn't made any difference. I think the Karoq load cover is slightly different in that the cover lifts upwards as the tailgate rises, so doesn't need to extend or retract much. It is only when you need to remove it completely or retract it completely that the problem arises - also the material is thinner and flimsier if it makes any difference. Has anyone successfully managed to get a new one under warranty, or managed to retention the spring mechanism? Skoda - Simply Slack
Door warning lights
Does anyone know if it's possible to replace the Red front door reflectors with working illuminated lights as per the Kodiaq? Just wondering if there is any wiring there in the existing door looms. Thanks.
