Everything posted by bigade1
Android Auto Enable
Your issue is that you need to enable the 2 settings as instructed at the end of your Vision Coding post. You will need someone with VCDS/0BD11 to enable the 2 settings and then you should be sorted. Here's a link to a Youtube video which explains the procedure:
Installing Speed Cameras on The Amundsen MIB2 - Free Database and Quite Simple to Do!
Updated Information ! This download is a new BETA/TEST Version! Ok everyone - here's some brief info. I haven't forgotten about my thread. Like yourselves I'm fed up of waiting to do a new update but the preferred database that I normally use and convert hasn't been updated or shared for quite a while. I've therefore borrowed the same sourced database that's being used for a totally different satnav device and converted them instead. This database uses different and somewhat confusing speedcam categories to the ones that I'm used to using so I've had to amalgamate some of them. Regard this update as a TEST VERSION and if you have any issues or feel they're not satisfactory then you can re-download my previous ones until I do a new update. All feedback is quite welcome even if it might take a while for me to reply. Latest Updated Speedcams - March, 2025. Here's the latest update of my customised version of EUR Speedcams ( March, 2025 ). They consist of the full EUROPE speed cameras which I've split up into three consolidated poi categories i.e. Redlight Speedcams, Fixed Speedcams and Average Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - March, 2025.zip * Credit to Sunnyside Navi and Gpsurl for the use of this database without which these files would not have been compiled.
Since the UK is part of Europe then you can assume correctly sir! Hence why I now abbreviate them to EUR to avoid any confusion. This is instead of referring to them as EU which we have now departed from.
Latest Updated Speedcams - September, 2024. Here's the latest update of my customised version of EUR Speedcams ( September, 2024 ). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Redlight Speedcams, Fixed Speedcams, Average Speedcams and Variable Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - September, 2024.zip * Credit, past and present, to Nyky from Gpsurl for the use of his database without which these files would not be compiled.
Latest Updated Speedcams - June, 2024. Here's the latest update of my customised version of EUR Speedcams ( June, 2024 ). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Fixed Speedcams, Average Speedcams, Variable Speedcams and Redlight Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - June, 2024.zip * Credit, past and present, to Nyky from Gpsurl for the use of his database without which these files would not be compiled.
Need software update file
It looks like P0253T is the latest official version for you: https://mib-helper.com/index.php?train=MST2_EU_SK_ZR_P0245T#details Post in this thread and pab567 might have the firmware for you if you ask him nicely: https://www.briskoda.net/forums/topic/477657-amundsen-mib2-firmware-update/
Wiring Diagram
No worries - it's just that you stated in your original post: and that link actually applies for the years from 2012 to 2017 pre facelift even though the description/title states " from 2012 ".
Wiring Diagram
Here's a link to the Mk III electrical wiring diagram. Hope this helps: https://www.dropbox.com/s/kgmd3icidrsr02i/Basic-equipment-L0L-From-November-2012.pdf?dl=0
Android Auto/Smart Link
Furthermore, it seems to me as if the ubercheap ebay fix did in fact work but you failed to enable the extra 2 settings that you were asked to perform using VCDS/OBD11. So yours is already activated. As I stated earlier in this thread have a look at the mr fix videos on youtube. This is the one that applies to your situation: https://www.youtube.com/watch?v=EdBYaaIVfVE
You need VCDS/OBD11 to enable a setting in the infotainment unit that displays the Green Engineering Mode ( GEM for short ). Then once the GEM is activated you can see and use the MIB2 Toolbox which you install and run from the sd card.
If you've got an Amundsen/Discover Media MIB2 unit it can be enabled for free. VCDS/OBD11, sd card and MIB2 Toolbox are all that are needed. Check out Mr Fix on youtube - he's got loads of videos explaining things.
Smart link enable
From a quick search on the internet it seems your unit is a Swing unit so it's neither of them. Therefore, I'd assume the toolbox won't work on your unit.
Infotainment system will not switch off when ignition removed
Turn the ignition key to the on position. If the radio is off then manually switch it on. Now remove the key while the radio is on and it should switch off automatically and should also start automatically when you reinsert the key and turn the ignition back on. Easy peasy.
New battery - lots of warning lights!
Don't panic its normal behaviour after changing a battery . After a few minutes of driving the faults will slowly disappear. You should use vcds/obd11 to programme the new battery in though. It'll still work but not at it's full capacity as the battery management system will still think the old battery is still in use.
Amundsen Mib2 Map Updates 2024
At last - they've released the long awaited new version. I expect @MartiniB will post the links soon but in the meantime here's a link for the full Europe 2210 v.19 map. Enjoy! : https://navigation-maps.volkswagen.com/vw-maps/DiscoverMedia2_EU-AS_2210_V19.7z
- 98 replies
- 4
- amundsen
- discover media
- maps
- mib
Tagged with:
Smartlink activation in south west UK
Check the video in my edited previous post. It definitely works. Sounds a bit technical but it's really fairly simple. Check the poster's other videos especially the one on how to install the toolbox.
Unlocking Android Auto/Carplay can be done for free on certain models e.g Amundsen MIB2 using MIB2Toolbox and VCDS/OBD11. Check this video out: https://www.youtube.com/watch?v=a9uwYmBPc1Q
Workshop Manual & Maintenance Schedule
As posted in the sticky above: https://www.hypermiler.co.uk/skoda/skoda-octavia-mk-iii-2013-workshop-service-maintenance-repair-manuals-downloads-inc-vrs-free And all for free!!
2.0 TDI 150CRMB alternator
If it helps my car is a 2017 pre facelift 2.0L SEL CRMB 150 bhp and in the list of the PR codes for my vehicle is the following entry: 8GU Alternators: Alternator 140В A I haven't removed mine to check the exact part no. but I've looked at an online parts catalogue which is more or less the same as the one used by TPS and there seems to be a lot of variations. The original alternator can be either a Bosch or a Valeo manufactured one and each manufacturer has different variations. The Bosch variations also have superseded models.
Latest Updated Speedcams - January, 2024. Here's the latest update of my customised version of EUR Speedcams ( January, 2024 ). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Fixed Speedcams, Average Speedcams, Variable Speedcams and Redlight Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - January, 2024.zip
Sorry it can't be done on a pc and no I'm afraid they won't work on your unit. Sorry they will only work on MIB2 units and possibly some MIB2.5 units.
It looks like your unit is a Harman unit so unfortunately these files will not work with your unit.
Overfilled the oil - what should I do?
Correct me if I'm wrong but my understanding of properly checking the oil level is for the car to reach operating temperature then SWITCH OFF engine and wait ten minutes and then you check the oil level. You don't leave the car idling for ten minutes. I'm sure that's what the label under the bonnet says but like I stated I stand corrected if I'm wrong. And obviously the procedure should be performed on a flat surface.
Latest Updated Speedcams - December, 2023. It's been a long wait this time - a whole year! - but at last here's the latest update of my customised version of EUR Speedcams ( December, 2023). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Fixed Speedcams, Average Speedcams, Variable Speedcams and Redlight Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - December, 2023.zip
Heater Support Pump
This is only my opinion. If, as you state, that the pump was changed on the 6th December then I would assume by the date shown on the error log i.e. Date: 2023.12.04 and the fact that the fault frequency = 1 that this error would be from the old pump and the fault just needs to be cleared.
