bigade1
Everything posted by bigade1
  1. Yup - as previously stated - there are 2 different manufacturers for the heating system. Denso and Valeo and they're not interchangeable. They've got completely different fittings. The simplest way to tell which system you have is to remove the glovebox and take a look at the plastic cover of your pollen filter. If it's the original cover it should have either the word Denso or Valeo brand moulded on it. Failing that look underneath your heater blower motor and there should be a sticker stating the make of it.
  2. Ok - I've just downloaded them to check them out and there is nothing wrong with them. The file contents and the file structures are all correct. I see from your profile that you have a 2016 car so it's possible that you may have a MIB1 device and if that's the case then I'm sorry as these files won't work for you.
  3. Latest Updated Speedcams - April, 2026. Here goes - Happy Easter lol. Once again here's the latest update of my customised version of EUR Speedcams ( April, 2026 ). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Redlight Speedcams, Fixed Speedcams , Average Speedcams ( which also include European tunnel speedcams ) and Variable Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - April, 2026.zip * Once again credit goes to jungblume2005 from Gpsurl for sharing his files which I borrowed and then converted in order to make this compilation.
  4. I'm sorry but I have no experience of the Skoda Karoq but from your picture I would say no. These files are for MIB2 units only. They will only work on the Skoda Amundsen and Columbus MIB2 versions as well as the equivalent VW Discover Media and Discover Pro versions.
  5. I guess you're referring to the brake disc dust cover. The same thing happened to me 2 weeks ago so I've just replaced mine. It's held on by 3 torx screws and the plate wears away and disintegrates around the screws causing the cover to become loose and then rattle. Only 1 screw was still holding mine on when I replaced it. Original replacement cover is approx. £30 from TPS but aftermarket ones are available from about £10 to £20 from the usual online marketplaces/motor factors. To gain access to the torx screws to either replace or remove the dust cover its a wheel off, pad and caliper removal, then caliper carriage removal and then disc removal ( the latter was a pain ). I actually cheated a bit because I removed the brake caliper carriage with the pads and caliper still attached. Some users have reported that the cover has just come away when the wheel has been removed and others have said been they've ben able to bend it back and forth to break it away. A lot of people don't bother replacing it because it's not a MOT requirement. My attitude is that it's there for a reason so it's a definite replacement job for me. At the end of the day it does protect the discs and pads and also saves premature wear of them.
  6. @paulski I take it that you've been lucky and never changed your brake light bulbs or front fog light bulbs ? 😁. I can confirm that it's to undo the 2 torx screws that you need to remove on each tail light to access the rear bulbs. On some models - such as mine - you also need the tool to undo the bulb holder cover. There should also be a silver springy thing with a hook to pull off the rubber covers that cover the two torx screws that hold the tail light in place.
  7. Latest Updated Speedcams - January, 2026. Here goes - my first upload for this year. Once again here's the latest update of my customised version of EUR Speedcams ( January, 2026 ). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Redlight Speedcams, Fixed Speedcams , Average Speedcams ( which also include European tunnel speedcams ) and Variable Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - January, 2026.zip * Credit to jungblume2005 from Gpsurl for sharing his files which I borrowed and then converted in order to make this compilation.
  8. “Error: No data available. Please insert a source with software update data or check the source.” This is usually an indication that the unit doesn't see any files on your sd card. I hope you're not making the basic mistake of placing the folder on the sd card because the unit will not recognise anything if it's contained in a folder. You must only copy the bare files or the folder contents to the sd card.
  9. Yup I've definitely exported it correctly - unfortunately I can only go with the database that's shared and it's from the exact same sharer and exact same database source. I even downloaded it twice because I myself even noticed that it contained a couple of files less than previous source downloads but it's out of my control.
  10. I'm sorry to hear that but that's out of my control. I'm using the same database ( SCDB ) from the same contributor as the July ones. I would revert to using the July ones for now and then check them again in my next upload. That's not saying they will return though - that's out of my hands I'm afraid.
  11. Latest Updated Speedcams - October, 2025. Once again here's the latest update of my customised version of EUR Speedcams ( October, 2025 ). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Redlight Speedcams, Fixed Speedcams ( which now include European tunnel speedcams ), Average Speedcams and Variable Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - October, 2025.zip * Credit to jungblume2005 from Gpsurl for the use of his database which was used and converted in order to compile these files.
  12. @Markules1981 I'm really sorry but I've got no experience with the Seat Leon.
  13. @francischase I'm sorry I've got no idea why this is happening to you - maybe a corrupt download? Try my latest ones below.
  14. Ok - just an update - we've solved the issue. As I suspected it was a fractured/broken wire which was causing all the issues. It's our belief that it was most probably caused by work that was done by the main dealer when changing a crankshaft sensor as the the issues started happening shortly after the car came back from them. Obviously this cannot be proven but at least we've sorted the problem. Happy days!!
  15. No but we will look into finding someone who can perform this. Thanks for the suggestion.
  16. Hi - my mate has a 2.0L diesel Octavia iv 2023 hatchback which has the oil pressure warning light along with a couple of other error codes persistently returning despite clearing the codes several times and completing the following maintenance jobs as advised by different mechanics. He has replaced the egr valve, oil pressure switch, oil pressure solenoid, wet oil belt ( along with checking and cleaning the oil strainer ), air flap actuator and both water pump c's. It's doing his absolute nut in so I've posted here in the hope that someone can offer any advice or suggestions. I have also included his obd11 log below. Personally it looks like to me as if there maybe an electrical issue but the local auto electrician couldn't find any issue. We both have no faith in our local main dealer after receiving the car overfilled with oil on one occasion after a service and noticing that the fuel filter had been drilled and a wrong screw fitted on another service occasion. Any pointers will be gratefully appreciated. Thanks. OBDeleven vehicle history log Date: 2025-08-15 19:42:47 VIN: TMBBJ******** Car: Year: 2023 Body type: UNKNOWN Engine: DTTA kW ( hp) l Mileage: 114390 mi --------------------------------------------------------------- 01 Engine System description: R4 2.0l TDI Software number: 05L906022HK Software version: 2088 Hardware number: 05L907309AA Hardware version: H80 Faults: P055F00 - Engine Oil Pressure Out of Range Intermittent Priority - 2 Malfunction frequency counter - 1 Unlearning counter - 40 km-Mileage - 183827 km Engine speed - 1006.50 1/min Normed load value - 28.2 % Vehicle speed - 4 km/h Coolant temperature - 75 °C Intake air temperature - 24 °C Ambient air pressure - 990 mbar Voltage terminal 30 - 12.380 V Dynamic environmental data - 209628395303202F0D37381D1BC34F7009E14FBE099E4F9700002CD80000 date - 2025-08-13 11:00:47 P023A00 - Charge Air Cooler Coolant Pump Control Circuit/Open Intermittent Priority - 2 Malfunction frequency counter - 20 Unlearning counter - 40 km-Mileage - 183824 km Engine speed - 929.00 1/min Normed load value - 18.0 % Vehicle speed - 0 km/h Coolant temperature - 89 °C Intake air temperature - 39 °C Ambient air pressure - 990 mbar Voltage terminal 30 - 12.100 V Dynamic environmental data - 209628448C03E844540B7D3E6E000001FB44560CD039530344B40F84 date - 2025-08-13 10:50:33 P06DA00 - Engine Oil Pressure Control Circuit/Open Intermittent Priority - 2 Malfunction frequency counter - 1 Unlearning counter - 40 km-Mileage - 183824 km Engine speed - 823.00 1/min Normed load value - 29.4 % Vehicle speed - 0 km/h Coolant temperature - 76 °C Intake air temperature - 24 °C Ambient air pressure - 990 mbar Voltage terminal 30 - 12.020 V Dynamic environmental data - 209628395303202F0D24381D15644F7009FA4FBE07A94F9700002CD80000 date - 2025-08-13 10:50:35 P26F400 - Coolant Pump "C" Control Circuit/Open Intermittent Priority - 2 Malfunction frequency counter - 1 Unlearning counter - 40 km-Mileage - 183824 km Engine speed - 865.50 1/min Normed load value - 22.7 % Vehicle speed - 0 km/h Coolant temperature - 77 °C Intake air temperature - 24 °C Ambient air pressure - 990 mbar Voltage terminal 30 - 11.980 V Dynamic environmental data - 2096284484101644540B733E6E0000013A51D40DA144830DAC44B410D1 date - 2025-08-13 10:50:34 P06DB00 - Engine Oil Pressure Control Circuit Low Intermittent Priority - 2 Malfunction frequency counter - 1 Unlearning counter - 40 km-Mileage - 183824 km Engine speed - 933.00 1/min Normed load value - 20.8 % Vehicle speed - 0 km/h Coolant temperature - 76 °C Intake air temperature - 24 °C Ambient air pressure - 990 mbar Voltage terminal 30 - 11.940 V Dynamic environmental data - 209628395303202F0D6B381D18D24F70099B4FBE08994F9700002CD80000 date - 2025-08-13 10:50:33 P040100 - Exhaust Gas Recirc.Flow Insufficient Detected static Priority - 2 Malfunction frequency counter - 28 Unlearning counter - 40 km-Mileage - 183803 km Engine speed - 1922.50 1/min Normed load value - 63.1 % Vehicle speed - 52 km/h Coolant temperature - 57 °C Intake air temperature - 33 °C Ambient air pressure - 980 mbar Voltage terminal 30 - 13.060 V Dynamic environmental data - 2096280846FD35446A048B0845FDC44472200044A61AF741D0FFC844CD2272 date - 2025-08-12 17:25:07 U041600 - Invalid Data Received From Vehicle Dynamics Control Module Intermittent Priority - 6 Malfunction frequency counter - 1 Unlearning counter - 35 km-Mileage - 183803 km Engine speed - 1000.00 1/min Normed load value - 19.2 % Vehicle speed - 0 km/h Coolant temperature - 35 °C Intake air temperature - 35 °C Ambient air pressure - 990 mbar Voltage terminal 30 - 11.860 V Dynamic environmental data - 20962352D90005416B200021160000 date - 2025-08-12 17:22:22
  17. Hi assybish - sorry to hear about your issue. I actually have the audible alerts turned off for my normal driving but I've had a quick test passing 4 known cameras in my locality and the audible warning worked as expected in both directions. Admittedly the alert was low in volume and it seemed to me as if the alert distance was a bit further away from the camera location than I expected but that's the standard settings. I would firstly suggest doing a hard reset of your entertainment unit. On the Amundsen MIB2 you just press and keep holding the power button until it knocks off but do not release the pressed button until the unit's splash screen turns back on. It usually takes about 15 to 20 seconds. This procedure does not alter any settings or change anything else so is perfectly safe to do without any consequences. I normally delete my current stored speedcams from the unit before I put my new ones on to avoid any possible data corruption. Are you doing the same? Failing that the only other suggestion I can make is to try a new redownload of my files just in case your original download had a slight corruption.
  18. Latest Updated Speedcams - July, 2025. Here's the latest update of my customised version of EUR Speedcams ( July, 2025 ). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Redlight Speedcams, Fixed Speedcams ( which now include European tunnel speedcams ), Average Speedcams and Variable Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - July, 2025.zip * Credit to jungblume2005 from Gpsurl for the use of his database which was used and converted in order to compile these files.
  19. Yea - I see what you mean. I've got no experience of MIB3 units only the MIB2 ones. MIB2 Amundsens must have the original sd card in them at all times while the MIB2 Columbus is a completely different method. Any third party sd card can be used to upgrade the map. The map is then stored in the onboard memory of the actual unit and therefore the sd card can be removed or deployed for another use. As you say MIB3 might be completely different and only the contents need to be copied to the sd card. The original poster did say his unit was a MIB2 though. As long as the file structure is kept to the same layout as his original sd card then he shouldn't have a problem but unfortunately he didn't do a backup.
  20. Yup - you're partly correct. I shall explain. This applies to the Amundsen MIB2 unit. The terms that are generally used are " nested " or " nesting ". The units will not recognise files if they are nested within another folder. So, for instance, if you extract a downloaded map then the result will be an extracted folder with the name of the map on it. if you then copy that folder to the sd card then the unit will not see the folder named " maps " or its contents because they are nested inside another folder. This is a common mistake that many people make. I still have my original Skoda Amundsen MIB2 sd card and I can confirm that the only folder on there is the " maps " folder so the the proper method of updating your maps is to delete the old " maps " folder and just copy the new " maps " folder in its place so it is in the exact format of the original card. Saying that, I also know from experience, that the sd card should work with just the contents of the " maps " folder copied to the sd card i.e. unnested.
  21. I can confirm that the metainfo.txt is definitely NOT needed so that's not your issue. I've never used it when I've updated my Amundsen MIB2 maps and I've never had an issue so your problem must lie elsewhere. I know this is obvious but I will re-iterate the following just in case. Firstly, with an Amundsen unit you can only use an official Skoda/VW sd card to use the map and this sd card must be kept in the unit permanently. Other sd cards won't work unless you perform a hack using the MIB2TOOL. Secondly, only the extracted folder named " maps " should be on the sd card. Thirdly and finally, your issue may be due to corrupted data. I've always used WinRAR to extract the map downloads and you should extract the folder to your pc NOT directly to your sd card. Once its been extracted to your pc then copy the " maps " folder to your formatted sd card. This is assuming that you're using a Windows PC - it's well documented that a linux system will sometimes add files to the extracted folder and cause issues. Also bear in mind that the Skoda Update portal is notorious for hosting corrupted map downloads. You're better off using the VW map links posted in this forum. They're usually 6 or 7 months ahead of the Skoda releases and are exactly the same maps but are renamed by Skoda. The links are here:
  22. I wouldn't panic if I was you. It could merely be a corrupt download. I'm assuming your unit is the Amundsen so you must use the original Skoda sd card. From what you describe your unit is not recognising the contents of the sd card. Just format the card again and make sure you DO NOT extract the map to the sd card. Instead, simply extract the map to a folder on your pc then copy and paste the extracted folder named " maps " to your sd card. You don't need to copy the 2 other files if they're present. They're not needed. If that doesn't work then re-download the map and try using winzip or winrar to extract the map.
  23. I expect @MartiniB will post the complete list of links when he's got some spare time but meanwhile here's the link for the new full Europe map: https://navigation-maps.volkswagen.com/vw-maps/DiscoverMedia2_EU-AS_2410_V21.7z
  24. Latest Updated Speedcams - April, 2025. Here's the latest update of my customised version of EUR Speedcams ( April, 2025 ). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Redlight Speedcams, Fixed Speedcams ( which now include European tunnel speedcams ), Average Speedcams and Variable Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them! EUR Speedcams - April, 2025.zip * Credit to jungblume2005 from Gpsurl for the use of his database which was used and converted in order to compile these files.
  25. I would say it's due to the merging of some categories and one of the icons being removed along with the ( invisible to the end user ) camera description data being edited by me when compiling them that's made them smaller in size. Overall the actual camera locations should be the same taking into account any removal or addition of cameras. No negative feedback so far but in any case I will be uploading very shortly a new compilation which will be in the usual original format thanks to a new contributer.
