Stewartasb
Everything posted by Stewartasb
  1. Lol your way better at finding parts than me Oh I did not get chance to look and gone.
  2. Just seems they are impossible to get hold off and mine has gone all spongy.
  3. Ok I popped out last night first time in a few months in the dark and when I turn on lights the dash is only dimly lit and won't brighten eith switch and the other interior switches etc are not illuminated ???
  4. Thanks Pete 👌
  5. I've tried to look online but can only find bottom hose.
  6. Also what is the int and ext diameter please.
  7. Hi does anyone know part number for the top hose from thermostat housing to top of rad please
  8. So parts ordered from all they have a good catalogue but jeez they take an eternity to dispatch lol ok so I'm doing a major brake service now when I bleed all the brakes with my eezibleed system I was considering bleeding the clutch also. Is this actually worth doing and will my eezi bleed do it and any pit falls to watch out for with the clutch ???
  9. Hi again so it appears I'm leaking oil from the above sensor but I'm totally unable to find a replacement any ideas please ???
  10. Thanks Pete super star as always 👍
  11. Hi do any of you fine people know part numbers or more so where I can obtain a rear driver's metal brake pipe to brake cylinder and also the main brake plate that you attach shoes and cylinder to I can't find any.
  12. Just remember to mark your locking nut position on the steering wheel and be careful with the air bag lol.
  13. Hi all so I had to pull the rear trim off the other day to run a wire and I've noticed the one connector that goes on the glass to power the heated screen has come off the glass, is there a way to reattach this or I've got no heated window come the winter ???
  14. I had same issue replaced stalk job done.
  15. Hi wiring a couple of switches and manual says there is a earth point by the handbrake but I can't find one does anyone know it's location or another point close to the heater switches that I can safely earth to ???
  16. Ok do latest gremlin is interior light when I lock the car it goes out after several seconds as it should but for the last week when I unlock and get in the car the light is stopping on constantly and not going off after several seconds as it was.
  17. Lol yeah I prefer to know it's done correctly and parts changed yes it's definitely leaking.
  18. Yes I have and I can see that the leak is from the clutch master cylinder I don't go to garages I do my own repairs I'm just not sure on the correct part number.
  19. Hi all, seems mine has sprung a leak firstly any issues to look out for when changing out and does anyone know the correct one or part code for my vehicle please as I keep getting conflicting searches for what fits thanks in advance
  20. I would deffo go with thermostat then drain coolant and access the heater matrix pipes and flush them with a jet wash i had to do this and it cleared the crap out of the heater matrix and freed it up.
  21. thats the remains of fly eye headlight wrap was on mine if you buy some good lab grade rubbing alcohol off ebay the residue will come off.
  22. that was an absolutely perfect entry point cheers for the heads up
  23. Yeah that's cool had it off before thanks for the info 👍
  24. Ah cool so that follows right down inside kick trim yes ???
  25. Hi all just a quick one. I need to route a main power wire direct from battery to boot is there any entry point from fire wall hidden or bunged that I can use as wire access ???
