Everything posted by Taz1983
Anyone whose fitted MFSW to a pre-fl, help please
1K0 953 549 AG is the steering controller I've fitted yet whatever I play with in VCDS, they never work. I had them working with another controller, but the steering sensor wasn't part of the module so the cruise didn't work. From all I can see, this module should let me use the MFSW yet clearly it doesn't I have the required wiring. Only other electronic mod I've done is fit a later gateway module to allow use of the RCD330. Could someone with a pre-fl share the module they have? Kinda tired of having the buttons and not using them!
SOLD - 4 x 16" Alloys for sale with tyres + centrecaps - off an Octavia MkIII
Hi, are these still available?
Anyone able to pull SKC for me near Leeds?
Hi everyone I want to programme a new key, but don't have the SKC, I have VCDS though. Is there anyone in or near Leeds who can do this for me? I don't really mind programming it myself, but the SKC I need to pull and been putting this off far too long. Cheers
After fitting new steering wheel control module, cruise stalk now "faulty"
The pin layout on 1K0953549CH is different to the original, specifically the cables going to the stalk. I have just refitted the original control module and alas, cruise works again. So now I'm wondering does the SW matter? I think perhaps my module is for cars with the standalone cruise stalk. It's difficult to find highline modules for this, hence opting for CH as they're easy to buy.
To stop battery drain on RCD330 headunit I fitted a later gateway module. To get the steering wheel buttons to work I changed the steering wheel control module. Now everything works but getting the cruise fault. It's possible the pin layout is different and the steering control module doesn't see the cruise as in later cars it had its own stalk
Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 VIN: Mileage: 212260km-131892miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.clb Part No SW: 03G 906 021 LB HW: 03G 906 021 LB Component: R4 1,9L EDC G000SG 8501 Revision: --H02--- Serial number: SKZ7Z0F3662083 Coding: 0000071 Shop #: WSC 73430 790 00000 VCID: 6ADB77AF457FE0D6AD-803E 2 Faults Found: 001384 - Cruise Control Switch (E45) P0568 - 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 212262 km Time Indication: 0 Date: 2000.00.00 Time: 14:28:13 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.39 V Bin. Bits: 11001100 Bin. Bits: 00000000 (no units): 0.0 005784 - Please Check DTC Memory of Steering Wheel Electronics P1698 - 001 - Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 212262 km Time Indication: 0 Date: 2000.00.00 Time: 14:28:13 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.39 V Bin. Bits: 11001100 Bin. Bits: 00000000 (no units): 0.0 Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl Part No: 1K0 907 379 P Component: ASR FRONT MK70 0105 Coding: 0017025 Shop #: WSC 73430 790 00000 VCID: 3F8DF6FB6E7DB57E2A-806A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1Z0 907 044 H Component: ClimatronicPQ35 084 0305 Shop #: WSC 00000 000 00000 VCID: 3B7582EB7A65A95E06-806E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000004252378 Coding: 418A0F030004140000110D000000000000087F075C Shop #: WSC 73430 790 00000 VCID: 2B55B2AB8A0539DE96-807E Subsystem 1 - Part No: 1Z2 955 119 A Labels: 1KX-955-119.CLB Component: Wischer SK351 012 0401 Coding: 00063477 Shop #: WSC 73430 Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB Component: RLS 220606 014 1201 Coding: 00471077 Shop #: WSC 73430 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q4 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD0KNUTM Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3D718CF36471A76E38-8068 Subsystem 1 - Serial number: 6332MSME10504D6FF Subsystem 2 - Serial number: 6342MSME10745B088 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH Component: J0527 056 0111 Coding: 0000133 Shop #: WSC 12345 123 12345 VCID: 7AFB47EF35DF50565D-802E Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 1 Fault Found: 00895 - Cruise Control Switch (E45) 014 - Defective ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 912 D HW: 1Z0 920 912 D Component: KOMBIINSTRUMENT VD1 1610 Revision: V1610036 Serial number: SKZ7Z0F3662083 Coding: 0007401 Shop #: WSC 28061 210 61833 VCID: 366393DF41477436F9-8062 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb Part No SW: 1K0 907 530 S HW: 1K0 907 951 Component: J533__Gateway H16 0210 Revision: H16 Serial number: 34000000000000 Coding: E9807F0E000202004301 Shop #: WSC 12345 123 12345 VCID: 377D9EDB464D8D3EE2-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 912 D HW: 1Z0 920 912 D Component: IMMO VD1 1610 Revision: V1610036 Serial number: SKZ7Z0F3662083 Shop #: WSC 00000 000 00000 VCID: 366393DF41477436F9-8062 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 005 0954 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 387F9DE74B538246EB-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb Part No: 1K2 909 144 L Component: EPS_ZFLS Kl.069 H07 1806 Shop #: WSC 02069 000 90108 VCID: 356194D35C417F2EF0-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0202 Revision: 00020000 Serial number: 00000000000000 Coding: 01801A085283007F3F04850540085F96907CA0 Shop #: WSC 73430 790 00000 VCID: 03053A0B4215119E0E-8056 Subsystem 5 - Part No: 1Z0 951 171 Component: Innenraumueberw.008 4801 Coding: 00000000 Shop #: WSC 73430 Subsystem 6 - Part No: 1K0 951 605 B Component: LIN BACKUP HORN H07 7001 Subsystem 7 - Component: NGS n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 005 0934 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 397998E370599B4E14-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 6RD 035 187 B HW: 6RD 035 187 B Component: Radio 541 5538 Revision: -------- Serial number: VWZZZ4H6290655 Coding: 0E000400040005 Shop #: WSC 127395 840 08317 VCID: 4683E31FF1A7E4B669-8012 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 159 Mileage: 212262 km Time Indication: 0 Date: 2000.00.00 Time: 14:28:14 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 005 0905 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 377D9EDB464D8D3EE2-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 005 0905 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 387F9DE74B538246EB-806C No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D718CF36471A76E38-8068
Hi all, I've recently fitted MFSW and the Steering Wheel Control Module which works with the RCD330 and the steering angle sensor. The only thing that has decided not to work is the cruise control, despite me having it selected in the steering module. Has anyone experienced this before? Cruise worked fine before changing this module. My only "solution" is to remove the MFSW and go back to how the car was originally as I'd rather have cruise than MFSW. I can get a VCDS log in around an hour. Cheers
RCD330 & Gateway Upgrade - Octavia 2007 VRS
I fitted 1K0907530S to mine and it programmed good. I think you're just looking for the age of part being newer than the Octavia.
Octavia II - steering angle sensor calibration - Ross-tech advice may not be "quite correct"
I don't think there is an easy way to reset the G85 sensor. I drove 100 miles with my steering heavy, and only after following the Ross-Tech guide to a T did it finally go out. I've heard the ABS sensors can throw the steering assist out, are you sure it's not just coincidence?
Flip to multifunction steering wheel and 1K0953549CH controller
Confirmed with RCD330, too?
MFSW problems
I've put an order in for 1K)953549CH. I will update once fitted to see if this solves the problem, which would mean MFSW + RCD330 requires LIN 2.0.
MFSW problems
Interesting observation. The wheel is from a 2006, the car is a 2007, with an updated gateway to stop battery drain with the RCD330. My brother has a 2010 Golf I can plug into to see what that has, as that has the RCD510 + MFSW which should broadly be similar. But I have never seen anyone mention the steering module can cause this, in any thread I've read about the RCD330, but it could be just that.
MFSW problems
Does 01317 have any significance? I can't seem to be able to modify anything in "Radio" now, at all. Previously I obviously could as I've fitted the RCD330 headunit and had to disable backup camera. The button on the wheel to light it up works, so it is registering. I don't know where to look for the other buttons in VCDS?
MFSW problems
Thanks for the reply Only when following the rosstech guide could I get G85 to calibrate. It has just sorted itself now, but took me a few days. So I'm back to where I was originally, functioning car without MFSW. They light up, they're getting power, so can only assume it's a software config issue but I find it strange using the wrong module without G85 the buttons did work. I'm not really in the mood to disconnect the battery again and do the G85 party but I can say that the settings I'm using now are the same I was using then. The amendments I'm trying to make to the gateway module I have changed before, so it is strange they've stopped working now. Anyway, I'll see if I can check the blocks now. Cheers
MFSW problems
This is in the current configuration. I cannot for some reason modify any radio settings, showing me error 31. Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 VIN: TMBBS21Z6780108XX Mileage: 208560km-129593miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.clb Part No SW: 03G 906 021 LB HW: 03G 906 021 LB Component: R4 1,9L EDC G000SG 8501 Revision: --H02--- Serial number: SKZ7Z0F3662083 Coding: 0000071 Shop #: WSC 73430 790 00000 VCID: 6ADB77AF457FE0D6AD-803E No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl Part No: 1K0 907 379 P Component: ASR FRONT MK70 0105 Coding: 0017025 Shop #: WSC 73430 790 00000 VCID: 3F8DF6FB6E7DB57E2A-806A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1Z0 907 044 H Component: ClimatronicPQ35 084 0305 Shop #: WSC 00000 000 00000 VCID: 3B7582EB7A65A95E06-806E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000004252378 Coding: 418A0F030004140000110D000000000000087F075C Shop #: WSC 73430 790 00000 VCID: 2B55B2AB8A0539DE96-807E Subsystem 1 - Part No: 1Z2 955 119 A Labels: 1KX-955-119.CLB Component: Wischer SK351 012 0401 Coding: 00063477 Shop #: WSC 73430 Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB Component: RLS 220606 014 1201 Coding: 00471077 Shop #: WSC 73430 3 Faults Found: 00987 - Lamp for Brake Light; Left (M9) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 64 Mileage: 208219 km Time Indication: 0 Freeze Frame: ON Voltage: 13.40 V ON ON OFF OFF OFF 00156 - Control Circuit for Windshield Washer Pump 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 102 Mileage: 208390 km Time Indication: 0 Freeze Frame: ON Voltage: 12.20 V ON ON OFF OFF OFF 02398 - Control Circuit for Rear Windshield Washer Pump 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00111001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 102 Mileage: 208390 km Time Indication: 0 Freeze Frame: ON Voltage: 12.20 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q4 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD0KNUTM Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3D718CF36471A76E38-8068 Subsystem 1 - Serial number: 6332MSME10504D6FF Subsystem 2 - Serial number: 6342MSME10745B088 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ Component: J0527 036 0070 Coding: 0002042 Shop #: WSC 73430 790 00000 VCID: 010930035809038E1C-8054 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 912 D HW: 1Z0 920 912 D Component: KOMBIINSTRUMENT VD1 1610 Revision: V1610036 Serial number: SKZ7Z0F3662083 Coding: 0007401 Shop #: WSC 28061 210 61833 VCID: 366393DF41477436F9-8062 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb Part No SW: 1K0 907 530 S HW: 1K0 907 951 Component: J533__Gateway H16 0210 Revision: H16 Serial number: 34000000000000 Coding: E9807F0E000202004301 Shop #: WSC 12345 123 12345 VCID: 377D9EDB464D8D3EE2-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 912 D HW: 1Z0 920 912 D Component: IMMO VD1 1610 Revision: V1610036 Serial number: SKZ7Z0F3662083 Shop #: WSC 00000 000 00000 VCID: 366393DF41477436F9-8062 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 005 0954 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 387F9DE74B538246EB-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb Part No: 1K2 909 144 L Component: EPS_ZFLS Kl.069 H07 1806 Shop #: WSC 02069 000 90108 VCID: 356194D35C417F2EF0-8060 2 Faults Found: 02546 - Steering Limit Stop 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Mileage: 208510 km Temperature: 55.0°C Voltage: 12.80 V Voltage: 12.60 V 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0202 Revision: 00020000 Serial number: 00000000000000 Coding: 01801A085283007F3F04850540085F96907CA0 Shop #: WSC 73430 790 00000 VCID: 03053A0B4215119E0E-8056 Subsystem 5 - Part No: 1Z0 951 171 Component: Innenraumueberw.008 4801 Coding: 00000000 Shop #: WSC 73430 Subsystem 6 - Part No: 1K0 951 605 B Component: LIN BACKUP HORN H07 7001 Subsystem 7 - Component: NGS n.mounted 1 Fault Found: 00896 - Trunk Lock Unit (F256) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 4 Fault Frequency: 25 Reset counter: 104 Mileage: 207990 km Time Indication: 0 Date: 2000.00.00 Time: 04:26:40 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 005 0934 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 397998E370599B4E14-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 6RD 035 187 B HW: 6RD 035 187 B Component: Radio 541 5538 Revision: -------- Serial number: VWZZZ4H6290655 Coding: 0E000400040005 Shop #: WSC 127395 840 08317 VCID: 4683E31FF1A7E4B669-8012 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 63 Mileage: 208461 km Time Indication: 0 Date: 2000.00.00 Time: 19:01:53 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 005 0905 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 377D9EDB464D8D3EE2-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 005 0905 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 387F9DE74B538246EB-806C No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D718CF36471A76E38-8068 No fault code found. End-------------------------(Elapsed Time: 01:43)--------------------------
MFSW problems
Hi Important numbers are in original post. Original is a midline with steering angle sensor built-in, I can confirm exactly tomorrow but not sure is any relevance as it didn't have the functionality for the MFSW. With the lights on the wheel lit up, it's obviously getting power. Do you know where I can check operation of the buttons? I haven't touched the gateway module between changing the steering controller so can't see it being that. The steering module settings mirror those I configured the "wrong" module to accept, and the only thing that didn't work was the steering angle, and cruise didn't work. Cruise works now, can't get my wheel to find centre and the buttons don't work. Tempted to go back to standard for now. Or would be helpful if someone with MFSW could share settings with me. Thanks
Air con pressure
What are your symptoms Tony? I changed mine and didn't make a difference. Going to check see if the cable has power later
MFSW problems
If you want that readout, I need to unplug the battery and connect the old steering controller (original). It can be done just takes a bit of time but if you think it's necessary I'll do it. Just amazed things aren't working right now.
MFSW problems
Hi I haven't / didn't save anything from the previous setup. The settings I have for the controller are as they were when the buttons did work. The wheel I am using is a MFSW w/o cruise or voice control (cruise & trip computer are stalk operated). Wheel, airbag, controller and wiring all from the same donor car, a 2006 Octavia. If possible, could you tell me what getting that print-out would do? I have only modified settings within the steering controller. Cheers
MFSW problems
I've fitted a MFSW and the steering control module + wiring to a 2007 Octavia. I bought 1K0-953-549-CF originally but this didn't have the G85 sensor built-in, so now I bought 1K0-953-549-AQ which was fitted to the same year car as mine. With AQ cruise didn't work, but I did get the buttons working. Now I can't for the life of me programme the buttons to work? They light up but I've selected everything in VCDS I can see. Also, the wheel feels heavier, but I haven't calibrated it yet properly, and it is showing position in VCDS. Can anyone help me? Have I done something drastically wrong? I thought AQ would solve my problems! Cheers
Fitted MFSW to '07 Octavia, now G85 error
I bought 1K0-953-549-CF which at first glance seemed perfect but the significance of "steering angle sensor" now means something to me. This part is listed as "No" here, where my old one (I believe to be -F), says "Yes". I get "00778 - Steering Angle Sensor (G85): No Signal/Communication" in VCDS. Now, am I forced into buying another Steering Controller, something like "BD", or can I change something cheaper, or a software change to get the sensor to show? I'm shocked at the cost of this module so would rather avoid purchasing another. TIA
Premature clutch slave failure
This is regarding a VW rather than SKoda, but the part is the same. 65 plate Scirocco, under 40k. Pedal has the spring but then goes to the floor (no pressure). The car sees it's on the floor so it will start. Why is this part plastic now, other than cost saving? I slowly feel VAG are shooting themselves in the foot. I'm seeing more problems on newer cars than ever before. Has anyone any other suggestions for what the problem might be, although it looks like the slave.
Xenon bulb recommendations
Not cool man. I've long thought Xenon's are too bright, but I've just got a pre-fl and I'll be fitting Osram's recommended above you. You shouldn't fit lights you shouldn't. You're on a car forum. You should be sending the right messages, not encouraging people to blind other drivers. Xenon's are already bright enough. If you want brighter lights, stop driving because clearly your eyesight is blown.
Coding MFSW to 2007 Octavia
I read somewhere you need a new steering wheel loom for this upgrade? But from this thread just need the wheel, controller and VCDS?
