Posts
12,579 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by sms
sms - Octavia II - May 2007 - Setember 2013 - 78356- never had this before, cost 1200 + labour + vat refuse to pay.
Tyre Pressure Monitor gremlins...?
sms replied to soapywalrus's topic in Skoda Octavia Mk II (2004 - 2013)
Well problem solved the tyre was flat yesterday morning but the garage couldn't find anything wrong, as the tread was getting low I decided to replace it, at least I know it works properly. -
My car is a w rated tyre car, front are y and one of the back is y and the other w could this be the problem the w rated one is the newest and the other back one (the y rated one) is half worn ? -
I'm having the same since a blow out Friday, they replaced the back tyre and now after they have warmed up the tpm goes off. Each tyre has the exact pressure, wondering if the tyre rating or make makes a difference? -
anyone installed anything that requires going into the car from the engine area?
Hi I need some help in installing a laser park pro, i have found where the wires come into the car on the passenger side but dont think there is enough room to fit what i need through there, plus difficult from the engine area. I have found a cap on the same area as the door switch wires goes through so am thinking of using there as nothing seems to go near there that could damage the wires. I want to put the buttons and led in the cigarette ash tray (drill the holes into it etc) as this will be easy to replace when i sell the car and also hides away nicely since i cant find a way into the air vent where i originally wanted to put the led and buzzer. lastly which wire is ignition on and which one is earth as i want to attach to these to so that when the ignition is off the unit is off. If anyone has had experience of putting one of these in there car i be grateful. many thanks in advance
keeping the revs between1500 and 2000 rpm helps and changing gear before 3,000 as its at 3,000 it starts to drink the fuel a bit more.
I've been told to check the balast by someone who had similar problems on a Renault. How do I check the balasts? What am I looking for
can anyone point me in the right direction as i dont want to hazzard a price from the stealers but im guessing they are coming up to being replaced, flickering and the colour more beige/yellow than the whitey blue like it once was. many thanks in advance.
I drive home every night in the dark so yes they used a lot. Another question which screw hole is for adjusting height and which way to put up the height? Lastly is this the same for both sides? I have vagcom which I've used to recalibrate the settings but for some reason they have dropped lower.
hi drmike where did you source them from? i dont particularly want to go back to stealers as they couldnt even put the headlight back in correctly.
How long should these bulbs actually last? mine seem to be having small black spots within the light and dont seem to be as bright. if i go over a bump the n/s one flickers but looks fine with them on stationary. Can these also be turned upside down as i have heard that helps??? also where can i source some decent ones from if it is a case of replacing them and how much would i be looking at? many thanks in advance.
service question 2nd service variable.
sms replied to sms's topic in Skoda Octavia Mk II (2004 - 2013)
hmmmm, well ive already said dont see me back for the 60k as for that price i might as well get trade the car in for something else. -
Just had my car back from mot and service today, 38k miles 2nd service and need to confirm some things. 1. does brake fluid get changed or is this charged as extra? 2. pollen filter is this changed on the second one as i had it changed on the first one? 3. spark plugs 2.0 fsi engine says in book 60k but the garage said its 40k and showed me on screen. All in all £467 :0 already been quoted for 60k which will be 220 quid for service, 350 something for cambelt and an extra 100 for water pump (after i mentioned the water pump known problem). certainly wont be going back and will be using vag com on it in a minute to see what else hasnt been done (usually head lamp callibration reset). There is a new independent vag garage opened nearby which i will be taking the car to in future as no doubt they be cheaper, so just wondering what £60k service prices people are getting as well as the 40k which i had today. On another note, Ross will remember checking my suspension, sure enough they looked at it today and claimed nothing is wrong with it, however the nsf now seems to be at the correct height and they said there isnt anything wrong with it? hmmmmm me thinks they told porkies.
mine is as you approach the house but gone once outside.. but then its dry as you approach the house and just been raining from outside.
Built In OEM Style Radar Detector
sms replied to gavindjharper's topic in Audio, Electronics and Security
search ebay for a road angel laser detector, it be a small black box with red leds on the front. then from road angel (think you have to ring them up for it as its not on their site) ask them for a number plate laser senser and extension lead. The sensor can be fitted to your lower grill with the help of a cable tie and wired into the car where if you take out your ashtray can slot in the road angel unit along with the wires and is out of sight. it can be removed easily if need be and no need for loads of holes. -
welcome
welcome to the site
Hi! Noob questions how to connect music device...?
sms replied to Dadslo's topic in Hellos and Goodbyes
welcome -
i did what tomtom said and it came to the stage where it would crash on the road, instead ive copied all the files back onto it that it originally came with (took a copy before it could update) and then did the update again and its working fine.
G-Park idecode redlaser glympse radiobox relax heyway and annoyateen which annoys my partner and daughter
The reason your company has told you to turn off your mobile is so no one in the company can get you when driving, so if you have an accident they cannot be held responsible for corporate manslaughter. It is illegal for the company to ring you when they know you are driving, so what they probably saying is if its turned off then its a sign you are driving so if anyone from the company rings and its off they are to try later when its on or leave a voicemail. Basically they are covering there backside.
