Everything posted by Nexus21
Soaked passenger footwells front and rear
Thank you both. I will check the rear door seals, i would never of thought to look there ! My VRs is a 2014 estate, so as Gaz says the earlier model was prone to reports of this. Sunroof water is running clear yes, I poured boiling water plus fairy liquid down the front holes,also put a curtain wire down both this afternoon. I’ll also have a look to see if there are holes under the back of sunroof near the glass but I don’t think there are. Door seals especially rear passenger side which is shown in the photo above seems the most likely culprit.This was as if a bucket of water was emptied in there ! At the moment I have her parked with both passenger wheels up on the kerb. Will be a few days until I can investigate further. Will let you know the outcome . Many Thanks guys.
Howdy ! Octavia mk3 vrs estate w sunroof 2nd day in a row (very heavy rain last night) Found this mess 2 days ago. Rug doctor sucked most of it up,wetter in the back. Thought it would be all dried out today when I went to put the mats back in. Even worse! Things I’ve done the other day - Poured boiling water n fairy down the small sunroof holes,a curtain wire down both too, Removed the glove box and pollen filter is bone dry Lifted the scuttle panel on the windscreen passenger side,poked where the sunroof channel ends inside scuttle panel,no debris I can see. Antifreeze level a bit low but normal. Heavy heavy rain last night, didn’t drive the car for days so it’s a coming from upstairs issue. Now parked up on the kerb with both psssenger wheels on kerb. Another 3 full Rug Doctor wet vac containers of water sucked up again today. Any thoughts please ? Thank you
What bulb is this please?
Hi there,not with the car atm,need to order pre mot,from the outside it looks like a fog light but could be a side light ? it’s a 2014 vrs estate thank you
Now £135 - £100 off what I paid-Set of 4 H&R 40mm Lowering Springs for Mk3 Octavia T.S.I
Great! That’ll pay for the van diesel for the trip 👍 Remind me after the bank holiday weekend will you?Cheers
I’ll be going to Canterbury/Herne bay by the end of May,possibly earlier,I can bring them down to you then if you don’t mind waiting ?
You can have them for £115 as I can’t post them,too heavy Too busy to post them atm
Hi these are the ones for your hatch,I have an estate so on loads of reading up,I got the correct ones after buying these and missed the returns window
Hi there,nope they are still there,can’t believe they have not been snapped up. Ill see if I can work out how to pm you Thanks
Tpms no option to “set” on infotainment
Note to self * DO NOT LEAVE MY GENUINE HEXv2 vcds in my Audi TT in Uk. Here in Ireland with my MQB vrs Skoda estate,the borrowed Chinese clone ****e will spit it out. TPMS code cleared with Snap On at a local mechanics for €40. This will accept and update the genuine article only.Heres what shows on Chinese crap and cannot be corrected.Also the “Set “ function will not show on the touchscreen,I presume until a full Autoscan and clear all fault codes has been accomplished,which it won’t with a knock off. Thank you to everyone for all of your help in following this problem
Tpms on board infotainment has no “Ser” option to reset dash warning light
F*+++ ing digital tyre gauge supplied LR44 batteries lasted about 4 minutes to get exact pressure 1st 🤬🤬🤬
Just charged up my varta n70 with less than 3 months on it to 13v. No joy from the infotainment as yet …. Amazon digital tyre gauge just now arrived so I’m gonna get them all exact as the petrol flap for my 18’s then I’ll go onto your suggestions guys,ref the software 👍👍
Hi yes and Thank you,yes “Tyres” does show up,I touch screen that and only further option is “ winter Tyres” and I could choose to have a 60mph speed limit option for “ winter Tyres” that’s it,nothing else,no other options
Thanks Skomaz,no links tho Sir… righto Paulski,I’m gonna pull the terminals off the battery in the morning anyway so will give it a few hours charge then follow your instructions there. Fantastic help everyone thanks I’ll post results/be back tomorrow 👍
Yes Skomaz,I did also think that today when I saw it on the screen….
Thank you Paulski,I’ve not done that,didn’t know about it👍That sounds great,I’ll do that.I did see it today - the controller map function,within vcds,so I just save that? All I do have is the ABS long code and todays long code saved to the desktop to copy and paste for “ New Code” but they are both the same long code unfortunately- me thinking I was being a detective 😩
Thank you everyone for your help. I WILL write a reply once a working solution arises.(Does my head in when someone asks for help and then you never hear from them again !😂)
Read up I will disconnect battery next and beep horn a few times to remove any extra juice in the circuit,then if that fails,I will add a few extra psi in each of the 4 tyres then let all air out to near zero then up again to specified psi (35 all around) and hope that jigs the TPMs system back into play
Yes that settings/gear icon does open up another menu( can’t remember what now but no reset TPMs😩 I did,however,work out how to use vcds and test the x4 tyre pressures and the x4 ABS sensors all gave a reading of approx 30mph,I was hoping 1 of the sensors would read at 0mph so now I don’t know where to go next Here’s a screenshot
Ref previous owner getting shot- Nope it worked fine for months.Ive tried the “ gear cogs Setting “ bottom right countless times and the reset is just not there anymore. Anyway with vcds ti see what each ABS sensor is pumping out?? Measuring Blocks is greyed out on this version,it only has advanced MB and I cannot see the option for above. was hoping I could have it “Live” and take for a spin so all 4 give a reading before getting the ramps out,it’s freezing and wet here in Ireland 🥶
Brilliant advice both chaps thank you. Ok so as I can’t work out how to do a Live record of each 4 abs sensors on vcds,I have also hooked up Delphi Autocom and it shows this…. Still cannot see how to do live on Tay either😩 I would just put in the mechanics in time to solve this issue for March 5th MOT but some lovely soul swiped the arse end of the parked up car 2 weeks ago and pootled off on their way,so I’ve ended having to buy x2 rear light clusters on eBay as the first was for a different car 🤬 I will have another look in CanGateway settings on vcds but I am thinking it is the ABS sensors system is the problem
I think that the infotainment upgrade is the issue myself.I have borrowed hex vcds today and cannot see how to change it.thought it is in Installation List is CanGateway but I’m really not sure
Can’t say for sure but it has Apple Play,Apps etc on the touchscreen.It was upgraded to this from its original system by the previous owner.
Yep mines a mk3 vrs estate 5e MQB with infotainment for the reset,there is no physical button to reset TPMS anywhere on the car. photos are 1.My car 2.The above YouTube video I’ve seen before,as I was saying,there is no “Set” to touch on the top right of touchscreen to reset as in the above YouTube video,it’s just not there 😩 It did come up as ABS
Thank you Paulski.I just checked and deffo no button in the glove box or the centre console.Ive also cross checked the ABS long code to a log file from vcds when it happened back in August 2023.The long codes are the same 😩 As someone said earlier,I do now believe it is down to a faulty ABS sensor ( 1 of the 4) but which one is anyone’s guess,don’t see how to this is achieved if no info on the infotainment screen
