bubib5
Everything posted by bubib5
  1. I do have a source for a parameter data file, so that wont be an issue, but the one on ebay is from a skoda, so i guess its plug and play, of course with minor adjustment
  2. Literally only one on ebay, not so cheap as well
  3. Ahh ok, so the only difference is the actual symbol, if programmed correctly number 3 button acts as massage function! Anyone have a part number to look for, cant seem to find a seat module with 3Q0 or i just am stupid
  4. and i assume it wont work without a button
  5. Variable floor is quite nice, keeing it up when you know you wont have any bigger items, makes it super easy to load as there is no load lip. When you need to haul bigger stuff just slam that bad boy down and off you go. There is a catch, for longer items needing to fold down seats, dont slam the floor down as you will have a big load lip transitioning from the boot onto the seats.. As for the boot liner, i got mine from super skoda, its rubber, felxible, and works with the flooring, you just need to fold it a bit when moving the floor as it can get stuck!
  6. I'll try and deal with this retrofit in the fall, from what I have seen on my superb the wiring is not there!
  7. Doesnt enabling it require aditional hardware? Or do you just code it and it works? How did you enable it if i may ask?
  8. Currently i have the stock ACC radar, i am sure i will need to purchase the newer radar, so CP removal is also a must! I have a friend with ODIS-E, so thats not a problem! I will check my current radar with obd11 in the morning, as well as my camera!
  9. Thank you for the input, i do have TSR, so all i would need is the newer PACC radar, and then the dataset-swap/fec magic.. So my best bet is to do the hardware chagne-the radar itself, and let someone do the coding magic remotley..
  10. Not wanting to hijack the heated windscreen retrofit thread, so started this one. Since seen its doable on virtually any 2105 and up MQB car, was wondering what is needed to make it happen on a MY2016 Superb, so far i gathered you need the A5 camera 3Q098065xx, as for the ACC Radar you need 3QF907561* (letter not important). Nothing other than that is needed if i am not mistaken? Now, once installed, i assume you need ODIS, first of all you need CP removed from the new radar, and camera if you need one, with that taken care of, whats the next step? Is parameterization needed, calibration, just coding, ODIS, or is Vag-Com enough, or VCP? @Krosta i recon you have previous experience with this retrofit? @AlVal You are doing this retrofit now? Care to share any info? Thank you to all who can help in advance!
  11. Ahh, any info where one might get the required SW to do it, sadly im nowhere near England.. And the hardware necessary would be that you already have ACC, and anything else? I do have ACC, lane assist, blind spot, TSR, emergency assist, rear cross traffic.. Does it need a newer MIB or will a MIB 2 do? EDIT: don know if it matters, but i do have working traffic jam assist, maybe that helps determine which hardware i already have
  12. Care to open a new thread ob retrofitting the pACC? that one sounds interesting..Thnx in advance!
  13. You can get boosting without QI charger, and with QI, mine is boosting only.
  14. not so sure about this, i think you can completley disable front assist!
  15. On a side note, i do have it inside the "ashtray" but for some reason i dont think its actually working, as i do have areas where i have low signal coverage, and its the same now, even if i place the phone on the pad, so wondering, how does it actually work, hos does it boost coverage, mind you i do have a larger phone which cant properly be seated in the pad, maybe that has something to do with it?
  16. Well, you learn everyday, i did recently remove the grille, in order to replace my chrome one with a black one, and was wondering what those plugs were for, now i know! Cheers!
  17. You cant remove the cover without removing the grille, or the bumper.. trust me, its way easier to remove the bumper rather than the grille. As for the fault, if you have acces to VCDS or OBD11 just hook it up and check for errors!
  18. Would love to, but, they dont ship to Croatia, and then even if they did, there are taxes as UK is not in the EU anymore, so i would preffer something inside the EU! But thanks for the input! If i dont find anything else i will shoot them an email and get a quote for shipping!
  19. Hey guys, tried searching the forums, and the internet, but cant seem to find OEM sun blinds/shades for a Superb Estate, nor can i find any reccomendations for aftermarket ones, prefferably in the EU.. I do have the factory tinted windows, but with 2 kids, one being a baby only 2 months old, its just not enough.. So has anyone sourced the OEM ones with part numbers, or can anyone reccomend any aftermarket sets that are good, i dont mind paying more, just need something thats worth it, i have seen numerous ads, but would love if someone has some that are pleased with? Thank you in advance!
  20. Yep, just tried mine today, and the right scroll wheel indeed does answer the call, you can end the call by pressing as well!
  21. I would say yes, but the only thing that might be different could be the seat release from the boot if the estate has one, and the hatch didnt, althogh not sure if that really matters at all..
  22. So i did dig a bit in VCDS, so far i got nothing, i did check my MIB settings, nothing there, so it cant be that. So for you guys, does it raise the same amount every time? Cause for me its not the exact same every time, and what i also noticed, when i try to lower it back down once i sit, sometimes it will not go all the way down on the first try. Really strange!
  23. Just a guess here, but maybe the scroll wheels can be pressed to answer, i changed my steering wheel buttons in order to retrofit the virtual cockpit, and since then have been pressing on the screen as well, havent tried the scroll wheels..
  24. Surely there has to be a solution for that, ill try to see if i can get anything on the output tests on VCDS, or if there is some way of teaching the seat what position is what.. Really strange, i thought i was the only one, at least its not uncommon then i guess.
  25. I will look through the MIB settings, but i dont recall activating it, could be that, i thought of that as i know Audi has one, where the seat raises a bit, and if you have an electric steering column that raises as well, but what puzzles me is that it never goes back down, and furthermore it does not do it for my wife, so what i am thinking it cant store the lowest position because it does not recognize it, so i was hoping there is a procedure to be done likewise for power windows where you need to teach it the positions!
