Everything posted by Brian15
Coolant leak
Found the part i need : 5Q0 121 156 C Just struggling to find a new one in the U.K as I need it sooner rather than later
Parts diagrams by VIN
Just paid for 24 hours access to partslink24 and it's playing up big time , anyone else on it and having problems ?
Coolant leak
Just had a friend who knows a bit more than me look at it , apparentky i need a thermostat to matrix hose , is that the correct name ?
Coolant leak
Been loosing a bit of water recently and I'm guessing this is why Is it possible to tell the cause , fitting , pipe or metal clip ? It's a 1.5 tsi octavia 3 69 plate Ll
Driveshaft supplier ?
eBay UKVOLKSWAGEN GOLF DRIVESHAFT DRIVER SIDE OFFSIDE RH 2020 1....PLEASE OPEN HERE FOR VEHICLE DESCRIPTION / DETAILS. Only done 16k, how genuine those miles are are anyone's guess on ebay
Been getting the clucking on full lock for a while and recently been getting vibration through the car Cars done 107k, 90k as a taxi so numerous visits over asda speed bumps, so rather than do one joint at a time thought might be as well to get the lot done
I'm struggling to find a supplier for my right hand driveshaft ,found left side ok, found a couple 2nd hand on ebay but no aftermarket supplier seems to stock them It's for a 69 plate 1.5 tsi octavia 3 I've got the correct codes off partslink which are : 5Q0 407 272 EC or 5Q0 407 764 FX Any help much appreciated
Misfire at 29-32 mph in 4th gear
Recently ran archoil through it , last few thousand miles have been tesco momentum so all should be clean Spark plugs are good Cambelt done a couple of months ago I've got some cheap £50 fault code reader that says all is good Smoke test is to check for any air leaks anywhere
Changed coil pack, no different. Booked in for smoke test and diagnostic next week
Coil pack question
Coil pack question
Having issues with jerking so looking at replacing coil pack My coil pack oem is 05E 905 110 , octaia 3 1.5 tsi 2019 DPCA Seen a pack on ebay same oem but but with an A on the end from 1.5 etsi vw golf mark 8 2023 DFYA Will they be ok for mine ?
Yeah , only got a pretty basic code scanner and nothing came up
Changed them recently
Which cv joint ?
Just been on the online chat with skoda to be told they don't give out parts numbers for security reasons :
Which cv joint ?
Cheers just emailed the customer services
Which cv joint ?
Trying to find out the correct outer cv joint for my car but been told 2 are correct but with slight size variations namely the length one says 97mm the other 99.5mm , it's for a 69 plate 1.5tsi, DPCA. Would the 2.5mm difference be critical on the length?
Pretty much as the title says Only occurs when cruising , press the accelerator to speed up and it goes Vibration through steering wheel has become more noticeable last few days Car is a 69 plate 1.5 tsi 107k Any help appreciated
Front Wishbones bushes separated
One of my bushes has started creaking over bumps (2019 1.5 tsi 105k 90k taxi miles) sprayed it a couple of times with silicone spray but needs sorting Mechanic advised it'd be more cost effective to change complete wishbone due to time involved changing bushes only Is this right and if so where is the best place to buy a replacement as I'm guessing the £50 sets on Ebay are better avoided ?
- Manual Gearbox Oil
Clicking noise when turning steering wheel
Same symptoms as mine It's in at local vag garage Monday for cambelt change, I'll get a diagnosis on the clicking and report back
Same problem myself , is there a way to tell or any signs for definite it is the cv joint ?
